05-28-2012, 18:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Nokia X6 No network after unlock RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35604603648022_BA CK.rpl" Phone type: RM-559 (Nokia X6-00) SW version: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia ApeCoreSw: V 40.0.002 Imei plain: 35604603648022-9 Product code: 0578257 Battery voltage: 4176 mV, current: 201 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356046036480229 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN I need help please |
05-29-2012, 04:31 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | go to Network seting check if network mode GSM 850 / 1900 GSM 1800 / 900 HSDPA 900 / 1900 / 2100 IF YOU SEE 1800 OR 900 IS IN YOU PHONE YOU CAN SAY IS SOFTWARE PROBLEM IF NOT THE PHONE CAN`T gate network in your country |
05-29-2012, 10:27 | #4 (permalink) |
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | of corse it has 1800/ 900 frequence. when i swich it on the phone it only vibrate, but if i swich it on with charge connected it powered on but with network. Any solution else? |
05-29-2012, 19:56 | #6 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BR, | ||
05-29-2012, 20:07 | #9 (permalink) |
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | your phone is not completely unlocked see yourphone Imei net: 356046036480229 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 unlock again |
05-29-2012, 20:22 | #10 (permalink) | |
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | Quote:
phone not unlocked log SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352012044204187 Version: SIMLOCK SERVER Provider: France Telecom Espaņa, SA , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=21403F [Spain-France Telecom Espaņa, SA ] | |
05-29-2012, 20:23 | #11 (permalink) |
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | RPL saved to "D:\mobileEx\3.5\data\backup\BB5_RM-356_352012044204187_SIM.RPL" Updating SIMLOCK...OK ++++++++++after unlocked log""""""""""""""""""" Reading Simlock info ... Imei net: 352012044204187 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-03-2012, 13:59 | #13 (permalink) | |
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Quote:
Imei: 354844045462432 Hash: 0B8BF6C46C51AB2B4BEFE00DB7B47F7B1BFF319B Status: finished Codes: #pw+603769740852425+1# #pw+436190820738698+2# #pw+358842688160249+3# #pw+273517023695497+4# #pw+375898060348412+5# #pw+241081486988729+6# #pw+474491414588439+7# Those are unlock code it me who blocked the phone because it doesn't capt network. Can i recovery my credit back if is possible please? | |
06-03-2012, 16:54 | #14 (permalink) |
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | How to unlock Nokia BB5 SL3 with MXKEY (step by step): 1. Identify phones with “Scan Phone” (as usual) to see if it is an SL3 phone. 2. Now go to “IMEI & Security” tab and select “Online Logger” 3. Click “Login“, and if your card is activated SL3 Unlock panel will be visible. 4. Click “Read Phones IDs” to prepare the data which is needed for brute force task (this will also identify if phone is supported or not) then a new file {IMEI}.sha will be created inside the main MXKey folder “{MOBILEEX}\data\SL3\” 5. Now you can select the {IMEI}.sha file and upload to our SL3 server along with the imei: *If you get a file back from our server which is {IMEI}.cod you need to download it, then go back to main exe, select the file and do “Calculate Codes” to get the unlock codes for your SL3 handset. The unlock codes will be saved as {IMEI}_SP_CODES.txt. You should then Tick “Send to the phone” to directly send the codes to the phone. YUO CAN UNLOCK YOU CODE IS IN Codes file saved to: C:\mobileEx\3.5\data\SL3\ Last edited by ::Evari77::; 06-03-2012 at 17:03. |
