Old 04-12-2010, 11:57   #1 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
1661 White Screen Hang..
Following is the scan Log..
SW Version: V 04.30 06-07-09 RH-122 (c) Nokia
Imei plain: 35********-5
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: EJ
Language Pack:
- not available.
Imei net: 35**********
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
When Power On is Pressed, Nothing appers on screen, only White light & Then Set Switches off after few seconds, I Tried Full erase & Then Flash it, The Problem remains there itself...
Can we resolve this one with MX Key??
Thanks
Old 08-14-2010, 14:10   #2 (permalink)
Member: 1342188
Sonork: 100.1607654
Thanks Meter: 129
mx key solved the problem, first click unluck after flashing the set your dct4+ unlucking will activate autometic
Old 08-14-2010, 14:20   #3 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
Ppm Id: EJ
Language Pack:
- not available.
Counter: 0/3, 0/10
Thanks
bro, change the lcd....than unlock it(unlock need because u erase it..otherwise lcd change will solved this problem)
100% solved.tested by me.
The Following User Says Thank You to shahinahmed007 For This Useful Post:
Old 06-08-2011, 13:41   #4 (permalink)
Member: 1557188
Sonork: 12345
i have nokia 1661 its hang and white screen...but i change the lcd ok...and after 2 min..problem desame...pls helf
Old 06-08-2011, 14:14   #5 (permalink)
Member: 1190352
Thanks Meter: 17
but i change the lcd ok.......................
6110 LCD Screen gsmxc Nokia Hardware & Hardware Repair 4 06-26-2004 06:03
6110 and 3210 LCD Screen pks Nokia Hardware & Hardware Repair 12 04-24-2001 12:45
8890 LCD SCREEN erikiiy Nokia Hardware & Hardware Repair 0 12-21-2000 23:37
Screening indicator cxara Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-09-1999 09:13
Page generated in 0.16124 seconds with 9 queries
