10-29-2009, 03:38 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: hanoi.vietnam
Member: 142949 Status: Offline Thanks Meter: 71 | now sever good ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499A3BDA66 ASIC type: 11 UEM Imei: 35955301704192 Connecting to server ...OK, Login ... Hello xxxxxx, you have 850 credits left. RPL saved to "E:\mobileEx\3.2\data\backup\RPL\35955301704192.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-105 SW Version: V 5.23 10-03-08 RH-105 (c) NMP Imei plain: 35955301704192-7 Product Code: 0549934 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 35955301704192 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! then full flash and unlock sing device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499A3BDA66 ASIC type: 11 UEM Imei: 35955301704192 Processing file: rh105_05.710 as MCU [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499:2984DA60 Area [01000000-0100FFFF] erased in 1.203 s Area [01010000-013AFFFF] erased in 1 min 9.609 s Area [013B0000-013EFFFF] erased in 4.734 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Programming completed in 16.140 s File Processed in 1 min 38.859 s Formating FS: FILE2 ... Processing file: rh1050_nai5.71mr as CNT [DCT4,DCT4 ALGORITHM] size: 139.57 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499:2984DA60 Area [01380000-013AFFFF] erased in 3.547 s Flash programming ... Programming completed in 0.953 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.015 s File Processed in 17.110 s Processing file: rh105_05.71mr as PPM [DCT4,DCT4 ALGORITHM] size: 1.20 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499:2984DA60 Area [01240000-0124FFFF] erased in 1.203 s Area [01250000-0137FFFF] erased in 22.907 s Flash programming ... Programming completed in 7.781 s File Processed in 38.875 s Flashing completed in 2 min 58.594 s After Flash Processing ... Updating Product Code OK. Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Uploading Product Profile Decompressing RH105_0549934_5.71_001.spr to C:\PROGRA1\Nokia\Phoenix\Products\RH-105\ OK Failed! PhoneType:RH-105 SwVersion: V 5.71 12-09-08 RH-105 (c) NMP MCU file: rh105_05.710 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D20499:2984DA60 Area [01000000-0101FFFF] erased in 2.390 s Area [01160000-0117FFFF] erased in 2.422 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 24.656 s Phone Type: RH-105 SW Version: V 5.71 12-09-08 RH-105 (c) NMP Imei plain: 35955301704192-7 Product Code: 0549934 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 35955301704192 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 50.157 s |
my 6680 water damaged now woking good on box & not work\chargw with battery | RazoR888 | Nokia Hardware & Hardware Repair | 7 | 10-09-2008 15:46 |
Pad Finder Not Work With Infinity - now working GOOD! | multicom_fsdpk | PadFinder box | 13 | 05-07-2008 11:35 |
mtpro sever down now pls check | aligsmpak | MT-BOX | 5 | 09-21-2007 10:31 |
