Old 02-11-2010, 09:17   #1 (permalink)
Member: 160709
Thanks Meter: 4
super sd auth ok! but not write pm,please help!
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
ApeCoreSw: 30.033
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 35 (16 bytes)
Warning: failed to write 1 - 37 (4 bytes)
Warning: failed to write 1 - 39 (36 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Warning: failed to write 1 - 45 (182 bytes)
- 120 skipped
- 308 skipped
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 3.625 s
pls help me,sir manole
Old 02-11-2010, 09:20   #2 (permalink)
Member: 783116
Thanks Meter: 52
try to select custom area in pm range and try again
Old 02-11-2010, 09:26   #3 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
ApeCoreSw: 30.033
Section: 1
- 120 skipped
- 308 skipped
Section: 309
post your full log.-------------
Old 02-11-2010, 09:33   #4 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
Change Pm file.Make sure you are not using wrong pm file.
Use pm of same type RM-247 .
Also there oughtn't any time delay b/w pressing Sd button and write Pm button.
Br,
Umair
Old 02-11-2010, 09:49   #5 (permalink)
Member: 160709
Thanks Meter: 4
bus check
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: 5117AF20AB76415704F00E4BB65E515429DD1FB5
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 04E0000BEB71005295A920DC5C6D0C927EE67963
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE
ALG [35]: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: 35486302596293
Original Product code: 0567018
Bluetooth ID: 0025477765CF
WLAN ID: 00254778502F
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 35486302596293-0
Product Code: 0572883
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354863025962930
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
sd auth:
ApeCoreSw: 30.033
write pm:
ApeCoreSw: 30.033
Section: 1
- 120 skipped
- 308 skipped
Section: 309
Completed in 4.281 s
6270 repair sd+super sd auth ok sucssss.....thanx manole... mathew_di MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 17:48
nokia 6600 software ok but ui settings failed please help mobilecitycbk Nokia Hardware & Hardware Repair 4 08-21-2007 09:13
6100 flash ok, but not power on, please help kaholukkk Nokia Hardware & Hardware Repair 3 08-23-2006 17:37
Page generated in 0.19873 seconds with 9 queries
