06-10-2011, 09:17 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Majuro, Marshall Islands
Member: 965137 Status: Offline Thanks Meter: 30 | Online IMEI Flash Failed! Reading ASK DATA ... ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001231A0:2984DA60 ASIC type: 2 UEM Imei: 011052000xxxxx SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\011052000xxxxx.RP L" ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001231A0:2984DA60 Programming FLASH Imei ...failed Phone Type: RM-225 (Nokia 6030b) SW Version: V 5.25 21-08-06 RM-225 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 011052008xxxxx Cellular System: GSM ASIC ID: 0x2031, type: 2 Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! ** Trying to restore back to 6030b RM-225 after reading post on this model. I flashed 6030 RM-74 and phone died. It flashed RM-225 (full erased) alright except for simlock & imei. |
06-10-2011, 11:45 | #2 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | UPDATE: Well, I have tick all available options 1x1 in imei rebuilder, imei change (patch method 1 & 2), Online Logger-both auto & manual, still no luck. Imei still "????????". What is wrong here? Repair simlock also failed Somebody? Anybody? Help newbie here.... |
06-10-2011, 11:59 | #3 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00873CF7:2984DA60 Programming FLASH Imei ...failed Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RM-225 (Nokia 6030b) SW Version: V 5.25 21-08-06 RM-225 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 011125001***** Product Code: 0539055 Cellular System: GSM ASIC ID: 0x2031, type: 2 Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! Help! I have 3 papaerweights here. Same problem. Was trying to convert to 6030 Rm-74 |
06-11-2011, 04:23 | #6 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | ASIC type: 2 UEM Imei: 01112500xxxxxx Updating SIMLOCK ...OK Updating SIMLOCK ...OK Phone Type: RM-225 (Nokia 6030b) SW Version: V 5.25 21-08-06 RM-225 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 01112500174582 Product Code: 0524916 Cellular System: GSM ASIC ID: 0x2031, type: 2 Ppm Id: M Language Pack: English,Cingular Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
06-11-2011, 05:45 | #9 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | ******* REQUEST RPL ******* ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00873CF7:2984DA60 Programming FLASH Imei ...failed Operation done with error. Still something I'm not doing right.... Anybody? |
06-11-2011, 06:13 | #10 (permalink) |
Member: 965137 Status: Offline Thanks Meter: 30 | ********** IMEI CHANGES *************** Updating SIMLOCK ...Error 1 Updating SIMLOCK ...Error 1 PhoneType:RM-225 SwVersion: V 5.25 21-08-06 RM-225 (c) Nokia. MCU file: rm225__5.250 Trying to find patch position ...OK, case id: 2 New Imei: 3583540075xxxxx ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001231A0:8909DA60 Area [010A0000-010BFFFF] erased in 1.281 s Area [010A0000-010BFFFF] erased in 1.281 s Programming ... Programming completed. Phone not responding ! Phone not responding ! ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8809 [Intel 28F128L18,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001231A0:8909DA60 Area [010A0000-010BFFFF] erased in 1.266 s Area [010A0000-010BFFFF] erased in 1.343 s Programming ... Programming completed. Still error..... Was trying to change IMEI..... I've done these bout hundred times on 3 phones/same model and still the same. Can somebody help please???????????????????????????????????????????? |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
