10-12-2011, 11:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: BISMI TRONICS
Member: 598334 Status: Offline Thanks Meter: 111 | please disable "Use New Protocol for RAP3GV3" in config (ANSWERED) MXKEY Flash LOG : MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: CXXXXXX Using device: HTI, FW ver: 00.24, SN: XXXXXXX Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) Processing MCU file: rm146__07.20.mcusw [BB5,BB5 ALGORITHM] size: 14.56 MB Supported Ids: 0103192101001101, 010C192101001101 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0920010CA4F06D56F3A2FFC44F93D0D6D155498B ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config Task failed at (08000008)!!! Last RX buffer: 00 00 01 00 00 00 01 00 00 00 00 E6 00 Infinity BEST flash log: Connect phone on selected interface... Core version : 1.30 Rev : 1.1 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm146__07.20.mcusw PPM : rm146__07.20.ppm_q CNT : rm146__07.20.image_q Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0920010CA4F06D56F3A2FFC44F93D0D6D155498B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLASHID : 220800EC , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Boot done! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm146__07.20.mcusw Init Erase Mode Ok Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:22 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm146__07.20.mcusw Init Write Mode Ok CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 947 blocks TIME : Write time : 00:01:45 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm146__07.20.ppm_q Init Erase Mode Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x015FFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:12 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm146__07.20.ppm_q Init Write Mode Ok Total writen 350 blocks TIME : Write time : 00:00:39 PrReq : NOR, 00 CNT : Converted to 128k page data exist TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Erase : Processing rm146__07.20.image_q_128 Init Erase Mode Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01600000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:27 PrReq : NOR, 00 TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual Write : Processing rm146__07.20.image_q_128 Init Write Mode Ok Total writen 256 blocks TIME : Write time : 00:00:28 PrReq : NOR, 00 Switch jaf to FBUS... FbusMode set Ok Phone connected Reading Phone Info.... Connected phone - Nokia 5300 Software Info: V 07.20 23-10-08 RM-146 (c) Nokia. IMEI: 3XXXXXXXXXXXXX Product code: 0538139 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Flashing done Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
