Old 02-04-2010, 04:00   #1 (permalink)
Member: 1212246
Thanks Meter: 283
PLEASE FIX This PROBLEM Sir MANOLE..
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 180.191.36.14
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
thanks for superdongle update and i fix my 5130,
but the problem now is after superdonge,
SIMLOCK_TEST passed
SECURITY_TEST failed!
now it only needs SX4 and WRITE PM
but your PM AUTH is not working..
please fix this problem..
more power mobile-ex team!
The Following 2 Users Say Thank You to TsambakolTeam For This Useful Post:
Old 02-04-2010, 04:04   #2 (permalink)
robbyslam's Avatar
Member: 114921
Thanks Meter: 16
Originally Posted by TsambakolTeam View Post
No SX4 Card found.
SIMLOCK_TEST passed
after repaire SD don't use PM AUTH , you can using Super SD AUTH then write pm 1 and 309 area
rgds
robbyslam
Old 02-04-2010, 04:05   #3 (permalink)
Registered User
GIGATT's Avatar
Member: 186342
Thanks Meter: 83
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.23 17-07-09 RM-436 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
warning: SD authorized but verify failed !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
sir same problem..
Unit: 7210c super_nova
GIGATT
Old 02-04-2010, 04:12   #4 (permalink)
Member: 1212246
Thanks Meter: 283
rgds
robbyslam
are u sure?
see this
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (12 bytes)
Warning: failed to write 1 - 1 (70 bytes)
Warning: failed to write 1 - 2 (70 bytes)
Warning: failed to write 1 - 3 (70 bytes)
Warning: failed to write 1 - 4 (70 bytes)
Warning: failed to write 1 - 5 (276 bytes)
Warning: failed to write 1 - 6 (276 bytes)
Warning: failed to write 1 - 7 (276 bytes)
Warning: failed to write 1 - 8 (276 bytes)
Warning: failed to write 1 - 9 (384 bytes)
Warning: failed to write 1 - 10 (384 bytes)
Warning: failed to write 1 - 11 (384 bytes)
Warning: failed to write 1 - 12 (384 bytes)
Warning: failed to write 1 - 13 (384 bytes)
Warning: failed to write 1 - 14 (384 bytes)
Warning: failed to write 1 - 15 (384 bytes)
Warning: failed to write 1 - 16 (384 bytes)
Warning: failed to write 1 - 17 (32 bytes)
Warning: failed to write 1 - 19 (16 bytes)
Warning: failed to write 1 - 20 (32 bytes)
- 120 skipped
- 308 skipped
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 5.734 s
all failed!!!
Old 02-04-2010, 04:17   #5 (permalink)
WILUNLOCK's Avatar
Member: 726741
Thanks Meter: 1,256
the mxkey has no superdongle error repair, the repair of full superdongle without addiction problems test me 1000% working
read this post one prolem solved a little difficult and a long time after the results were excellent
http://forum.gsmhosting.com/vbb/showthread.php?t=918241
Old 02-04-2010, 06:09   #6 (permalink)
Member: 1212246
Thanks Meter: 283
mx-key super sd damage pm 308 of this phone
BAD BAD BAD work....
tsk tsk tsk!
Old 02-04-2010, 06:32   #7 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
superdongle repair = ok
but
security failed = not ok
Old 02-04-2010, 06:36   #8 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
yea same here i thought that its happening only with me but now its clear that many users facing the same BUG in the new Update
WBR
G S M - D O C T O R
The Following 2 Users Say Thank You to GSM-DOCTOR For This Useful Post:
Old 02-04-2010, 12:16   #9 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
i think this new update of XMKEY SW is in BETA mode
not yet perfectly working.....(am i wright? )
take your time MXKEY team,..........
br,
please fix this problem shasse FuriousGold 4 01-26-2009 11:07
Please fix this problem with flash!!! spawoolm HWK 1 09-18-2008 11:13
please fix this problem in jtag tool OTMAN-GSM Multi-Box 4 03-19-2007 07:00
****PleasE FIX this ProbLeM**** H@cker1 IQ-Box 7 02-17-2007 15:36
K310, K510 can't unlock with UB, please fix this problem gsm-brest Universalbox 4 01-29-2007 19:45
Page generated in 0.24745 seconds with 9 queries
