Old 03-06-2010, 09:04   #1 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,664
Arrow Please help any master mind
The Following User Says Thank You to jawedakht For This Useful Post:
Old 03-06-2010, 09:08   #2 (permalink)
Member: 573721
Thanks Meter: 6
Whats the problem mate?
Old 03-06-2010, 09:18   #3 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,664
SEE THE LOG
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1BF0000FA9467E56FB5394A0E8484C8EFB3EF126
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
ID 32: 0002FFFFFFFF
Flash ID not supported for this loader (RAP3Gv3_algo.fg)
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
loader not responding (0200000000D172)
Flashing terminated with error(s) in 31.218 s
RX Buffer: FFFFD372
Old 03-06-2010, 09:21   #4 (permalink)
AYAZ42's Avatar
Member: 833620
Sonork: 100.1586892
Thanks Meter: 259
wats ur phone problem
Old 03-06-2010, 09:22   #5 (permalink)
Member: 63457
Thanks Meter: 26
man disconect ufs and connect again,,,,,,,
Old 03-06-2010, 09:32   #6 (permalink)
Registered User
Member: 620883
Thanks Meter: 38
disconect ufs and connect jaf 1000000000% okkkkaaaa
Old 03-06-2010, 09:43   #7 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,664
I have tryed by jaf ,hwk micro,but same result same
Old 03-06-2010, 09:57   #8 (permalink)
laxman kumar's Avatar
Member: 733702
Sonork: 100.1579452
Thanks Meter: 579
try to flash with usb post reply
Old 03-06-2010, 10:19   #9 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 245
also i face this problem
Old 03-06-2010, 10:21   #10 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 99
it is the Flash IC problem try with hardware
Old 03-06-2010, 10:51   #11 (permalink)
Member: 554531
Thanks Meter: 85
Originally Posted by jawedakht View Post
1. go to option
2.module-nokia service tool
3. click on option
4.go to flash update directory and change flash loader.100%tested.
Old 03-06-2010, 11:06   #12 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,664
Originally Posted by dilipnachna View Post
1. go to option
3. click on option
sir i no understand your language pls details
Old 03-06-2010, 11:09   #13 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
bro
there is bug in ufs intreface while you want to flsh dct4+ model
for the moment use jaf as interface
for dct4+ models
Old 03-06-2010, 12:15   #14 (permalink)
Member: 554531
Thanks Meter: 85
ok 1.2.
3.
4.
regards.
The Following User Says Thank You to dilipnachna For This Useful Post:
Old 03-06-2010, 13:05   #15 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,664
ok 1.2.
3.
4.
regards.
same result pls help
``help.help. nokia 5130c after flash imei 123? i have backup help..any master >>.123.<< MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-10-2010 18:16
3650 imei chang need plz help me any master mind mobiletuch Nokia Hardware & Hardware Repair 8 11-23-2009 15:34
Any Master Mind Is There. E 315 No Light In Display. Give Dis.conec Track shahi Samsung Hardware Repair 0 01-30-2007 08:13
Page generated in 0.36057 seconds with 8 queries
