12-06-2012, 06:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Where Dreams Become Realit Age: 28
Member: 645436 Status: Offline Thanks Meter: 1,501 | Please help me nokia 6120c SW version: V 06.01 02-09-08 RM-243 (c) Nokia ApeCoreSw: 06.01 Imei plain: 35593804212176-6 Product code: 0567074 Battery voltage: 4794 mV, current: 0 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SECURITY_TEST failed! Imei net: 355938042121766 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN any one help me nokia 6120 br msattar123 |
12-06-2012, 07:58 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | http://forum.gsmhosting.com/vbb/f550...wered-1031277/ read this thread you can solve and try thia also |
The Following User Says Thank You to ::Evari77:: For This Useful Post: |
12-06-2012, 08:09 | #3 (permalink) | |
Member: 645436 Status: Offline Thanks Meter: 1,501 | Quote:
12-06-2012, 11:07 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote: 1st. Use this Method, Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-243.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
12-06-2012, 21:16 | #6 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Quote: Asking Pm or giving ? notice nicely problem solved or not? br snmobilecenter | |
The Following User Says Thank You to snmobilecenter For This Useful Post: |
