09-19-2011, 05:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Hong Kong Age: 45
Member: 229358 Status: Offline Thanks Meter: 12 | please help , what's wrong ?? MXKEY Serial: [FT SCR2000 0] - C0843xxx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: OHCI:HUB:HUB:USB 1.10 (Full-speed) Driver: UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.4.16.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14400108AB81005282F2DE089A47D96237E77C81 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! |
09-19-2011, 08:07 | #3 (permalink) |
Member: 229358 Status: Offline Thanks Meter: 12 | what can i do for this phone ?? when power on , only show "phone start up failed . contact retailer " .... MXKEY Serial: [FT SCR2000 0] - C084xxxx Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20CC1644 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 14400108AB81005282F2DE089A47D96237E77C81 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF Original Imei: 00000000000000 Original Product code: SIMLOCK PA identifier: [0] PA_SL3 [1] PA_SL Reading CMT NPC (0xFF bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0xFF bytes). Reading CMT HWC (0xFF bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 5530 XpressMusic USB Phonet, PORT_ID: 36E69F98 Verifying communication to device OK. Phone type: RM-504 (Nokia 5530 XpressMusic) SW version: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia Imei plain: 35802203663683-7 Product code: 0589023 Battery voltage: 3796 mV, current: 216 mA ApeCoreSw: V 32.0.007 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-19-2011, 10:32 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | Quote:
If you backup RPL, just restore it. If you have no backup RPL, then the solution is only by buy RPL. | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
