Old 07-22-2010, 09:49   #1 (permalink)
utsav_jayesh's Avatar
Member: 314847
Thanks Meter: 102
Please select correct loader version from 'Config' menu !
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 06900009F69600529A7554DE62D34A3481C71DE9
ASIC MODE ID: 00
ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (POTATO BOX, FW ver: 01.B1).
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
what is this problem and how to solve this mx-key team.
The Following User Says Thank You to utsav_jayesh For This Useful Post:
Old 07-22-2010, 09:59   #2 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
bro,uninstall mobile ex,and make backup of data folder after that delete all folder of mobile ex from c drive ,after that instal mobile v3.4 ex(rev1.2),in this suit no need to select loader manually,
i hope ur problem will be solved.
The Following User Says Thank You to adityajha For This Useful Post:
Old 07-22-2010, 10:08   #3 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
if not solve than check ur usb cabel by which u r connecting interface,and also chek ur bus cable.
Old 07-22-2010, 10:10   #4 (permalink)
Member: 314847
Thanks Meter: 102
Version Info:
MCU SW version: V ICPR71_09w22 29-05-09 RM-437 (c) Nokia
HW version: 0904
RFIC version: 17141716
DSP version: sofie-ICPR71_09w20
APE SW Core version: 200.21.012
APE Variant version: 200.21.012200.21.012_v267.03
APE Test version: RM437ENO874571920.014
Retu version: 16
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
WLAN Id: : 00 BB 43 62 33 75 D8
Product Info:
Production serial number: MSC629467
Product code: 0585258
Basic production code: 0561985
Long production SN: 0
Serial Numbers:
IMEI plain: 35200904499xxxx
IMEI spare to net: 3A 25 00 09 44 99 24 01
IMEI SV to net: 33 25 00 09 44 99 24 01 F5
NCK: Other Info:
Model : Nokia E63 (Smartphone)
CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII
BSI: 5.7 KOhm
Imei net: 352009044994213
Version: SIMLOCK SERVER
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F
BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F
BLOCK 3: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F
BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F
i want unlock this phone
Old 07-22-2010, 10:18   #5 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
mx-key supported model
Supported BB5 SUPERDONGLE RPL:
All Available phones in the market based on RAP3Gv2,RAP3Gv3 and RAPIDO
with SLPA and SL20 and SL3 SIMLOCK version
Supported BB5 SIMLOCK RPL:
with SLPA and SL20 SIMLOCK version
Supported BB5 NCK Code Reader:
Supported BB5 No TP Unlock(OLD METHOD):
RAP3GV2:
-6630 (RM-1)*
-6680 (RM-36)*
-6681 (RM-57)*
-6682 (RM-58)
-N70 (RM-84)*
-N70-5 (RM-99)
-N71 (RM-67)
-N90 (RM-42)*
-N91-1 (RM-43)
-N91-8GB (RM-43)*
-N91-5 (RM-158)*
-N93 (RM-55)
RAP3GV3:
;Relock also supported
-3109c (RM-274)
-3110c (RM-237)
-3250 (RM-38)
-3500c (RM-272)
-3500cb (RM-273)
-5200 (RM-174)
-5200b (RM-181)
-5300 (RM-146)*
-5300b (RM-147)
-5500 (RM-86)
-5700 (RM-230)
-5700 (RM-302)
-6085 (RM-198)
-6086 (RM-188)
-6086b (RM-260)
-6125 (RM-178)
-6126/6133 (RM-126)
-6131 (RM-115)
-6131 NFC (RM-216)
-6136 (RM-199)
-6151 (RM-200)
-6233 (RM-145)*
-6234 (RM-123)*
-6280/6288 (RM-78)*
-6290 (RM-176)
-6300 (RM-217)*
-6300b (RM-222)
-7370 (RM-70)
-7373 (RM-209)
-7390 (RM-140)
-8600 (RM-164)
-E50 (RM-170)
-E50 (RM-171)
-E50 (RM-172)
-E61 (RM-89)
-E61i (RM-227)
-E62 (RM-88)
-E65 (RM-208)
-N73-1 (RM-133)*
-N73-5 (RM-132)
-N75 (RM-128)
-N76 (RM-135)
-N76 (RM-149)
-N77 (RM-194)
-N80-1 (RM-92)
-N80-3 (RM-91)
-N92 (RM-100)
PA_SL2:
-3120C (RM-364)*
-3555 (RM-277)
-3555b (RM-257)
-5310 (RM-303)*
-5310b (RM-304)
-5610 (RM-279)
-5610d-1(RM-242)
-6263 (RM-207)
-6300i (RM-337)
-6301 (RM-322)
-6500s (RM-240)*
-6500c (RM-265)*
-6555 (RM-289)
-7500 (RM-249)
-7900 (RM-264)
-8800 (RM-165)
exception(Not supported, new security[PA_SL3]):
-3600s(RM-352) V56.26
-5310 (RM-303) V58.58
-6500c (RM-265) V59.45
-6500s (RM-240) V59.60
-6300 (RM-217) V57.20
RAPIDO:
-N95 (RM-159)*
-N95 (RM-245)
-N95 (RM-160)
-E90 (RA-6)
PA_SL2:
-6110 (RM-122)
-6120c (RM-243)*
-6121c (RM-308)
-6124c (RM-422)
-6210 (RM-367)
-6220c (RM-328)
-6290 (RM-176)
-6650 (RM-400)
-E51 (RM-244)*
-E66 (RM-343)
-E71 (RM-346)
-N79 (RM-349)
-N95-2 8GB (RM-320)
PA_SL2 with Protected PM(NCK Read):
-E75 (RM-412)*
-N96 (RM-247)*
-N85 (RM-335)*
-5800 (RM-356)*
-6220c (RM-328)*
Supported DCT4PLUS Patch Unlock:
-1110i (RH-93)*
-1112 (RH-93)*
-2310 (RM-189)*
-2610 (RM-189)*
-1650 (RH-86)*
-1200 (RH-99)*
-1208 (RM-205)
-1209 (RM-105)*
-2680 (RH-392)
-5000d (RM-362)*
-2600c (RM-340)*
-2626 (RM-291)*
-2630 (RM-298)*
-2670 (RM-258)*
-1680c (RM-394)*
-2330c (RM-512)*
-2323c (RM-543)*
-2720a (RM-519)*
-7100s (RM-438)*
*) tested.
Old 07-22-2010, 10:26   #6 (permalink)
Member: 314847
Thanks Meter: 102
cable is good and it's i-pmart red cable maybe something strange problem.
Old 07-22-2010, 10:56   #7 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
r u uninstalled and deleted all folder of mx-key from "c" drive.after that reinstall latest suit 3.4 rev1.2
Old 07-22-2010, 11:47   #8 (permalink)
Member: 314847
Thanks Meter: 102
yes i try that but same error. still same
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Old 07-22-2010, 12:23   #9 (permalink)
Member: 696872
Thanks Meter: 18
pls do it
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
open your mxkey
open nokia service tool
open config
set directory
set dt4/bb5 loder directory
bro your problem is solve 100%
Old 07-22-2010, 13:49   #10 (permalink)
Member: 314847
Thanks Meter: 102
Originally Posted by ashish51047004 View Post
open your mxkey
open config
set directory
i try also that but still same brother
Old 07-22-2010, 19:45   #11 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
i have ufs and jaf only any soultion for that
The new protocol is supported ONLY in ATF interface, this is new interface
and they care to make new updates of their firmware to support new Nokia
protocol of new phones.
Old interfaces will never be supported because of old hardware and firmware.
BR,
Manole
Old 07-23-2010, 02:44   #12 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
new protocol is supported in ATF or JAF interface..but not UFS interface ..tested .
Old 07-23-2010, 05:26   #13 (permalink)
silicon brj's Avatar
Member: 622060
Thanks Meter: 37
Jaf can flash new nokia products like-1661,1202???
BR,
Manole
sir jaf can flash nokia 1661, 1202 ?
Old 07-23-2010, 08:27   #14 (permalink)
Member: 314847
Thanks Meter: 102
jaf is not supported interface for new protocol chek my 1st post.
Old 11-29-2010, 10:33   #15 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
BR,
Manole
@MANOLE
thanks for the update! but any better reason why after buying ATF, should use it as an interface with mxkey? why not use ATF with its software and do the job!
well this policy doesn't work! tommorow due to new phones maybe MXkey supports only FPS-8 as interface! so should we buy FPS-8 for that? well this being a cheap dongle so as to use different interfae, should be updated to support some old or cheap interfaces! just a suggestion.....
WBR
ReyTech.
The Following User Says Thank You to ReyTech For This Useful Post:
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.31920 seconds with 9 queries
