03-11-2011, 14:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Please select correct loader version from 'Config' menu ! (ANSWERED) |
03-11-2011, 14:42 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hello, on the logs above indicates that phone being attached is came with new security. ufs as interface can not handle these phones. you can use usb as interface for flashing. |
03-11-2011, 14:51 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | You can See this Post & Use mxkey 1.7 or 1.9 Best of Luck Select Loader from Config Menu. http://forum.gsmhosting.com/vbb/f550...0/#post6967753 |
03-11-2011, 15:33 | #4 (permalink) | |
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Quote:
brother i used 3.4 ver 1.9 but same error and also try to flash via usb but no success | |
03-12-2011, 04:36 | #5 (permalink) |
Freak Poster Join Date: Oct 2007 Location: live in mobile's heart
Member: 600282 Status: Offline Sonork: 100.1614516 Thanks Meter: 67 | your phone will come alive in the following way 1....use atf as interface.... 2... flash your phone with 7.10 apac which has four files the fourth one is eno file then write the blank ppm file in ppm field. search for blank file "blank_504KB_pmm_10.fpsx" good luck and press thanks if u like it and do remember that dont erase this phone you cant repair simlock of this hash with any tool |
03-13-2011, 08:27 | #6 (permalink) |
Freak Poster Join Date: Apr 2007 Location: INDIA
Member: 481435 Status: Offline Thanks Meter: 151 | i" m same facing in ver 1.9 showing every time msg when i open mxkey (Market items is empty, please select the correct products path ) (but when i was installed ver 1.7 everything was perfect)..i again manul set path dct4/bb5 flash loader directory (C:\mobileEx\3.4\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\09.50.25.2\) i try 8 & 10 but same & 2ndly when i select model list d"nt see model list...so what can i do?????????? Last edited by pavi; 03-13-2011 at 08:29. Reason: coorection |
03-13-2011, 09:20 | #10 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | maybe rev 1.9 have bugs check my post here: http://forum.gsmhosting.com/vbb/f550...e-fix-1225518/ br |
03-13-2011, 09:28 | #11 (permalink) |
Member: 481435 Status: Offline Thanks Meter: 151 | my loader problem is be solved.but i d"nt see model when i installed files in C:\Program Files\Nokia\Phoenix\Products) then showing littel model list..not see all model... |
03-13-2011, 10:07 | #12 (permalink) | |
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
may be your files are in another folder, do u check your harddisk in C:\Program Files\Nokia\Phoenix\Products? how many products' files in that folder? if there are some files stored in another folder, add the folder again in settings. good luck bro br | |
03-22-2011, 06:12 | #13 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: purwakarta . indonesia
Member: 1007708 Status: Offline Thanks Meter: 27 | config list market Quote:
see a pic where is wrong configuration setting ... | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
