04-08-2010, 20:02 | #1 (permalink) |
Registered User Join Date: Sep 2006
Member: 341881 Status: Offline Thanks Meter: 4 | pleis problem mxky Provider: Vodafone / Airtel Movil, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 21401F PhoneType:RM-258 SwVersion: V 05.61 18-04-08 RM-258 (c) Nokia MCU file: rm258__05.61.mcusw Trying to find patch position ...OK Boot error: 4F 4E 00 4F - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Retrying ... OK, case id: 4 Boot error: 4F 46 46 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Boot error: 4F 46 46 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. help pleis |
6350 can i unlock with mxky | Tanveer_city01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 08-31-2010 21:13 |
n73 display problem | neeraj1st | Nokia Hardware & Hardware Repair | 2 | 04-27-2010 09:57 |
problem after update my box no open any program err 18 any solution ? [ANSWERED] | Braycel | Genie Universal | 13 | 04-09-2010 00:55 |
how to change imei in dct4 using mxky | Ginerz | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-07-2009 15:29 |
My mxky is not active..... | tanvir_guru | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-21-2009 13:39 |
