Old 10-18-2012, 17:16   #1 (permalink)
sweathasreekant's Avatar
Member: 1745727
Sonork: 100.1617904
Thanks Meter: 65
pls hellp me my mxbox No Security Dongle detected
pls help me mxkey teem my mxbox No Security Dongle detected i have lootof worek withe mxbox verye urjent pls help me pls chek this screenshot and replay must
Uploaded with ImageShack.us
Old 10-18-2012, 18:16   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
It's driver problem contact me pm.
BR.
Arsalan gsm2000.
Old 10-18-2012, 18:23   #3 (permalink)
Member: 836414
Thanks Meter: 17
just remove the box check the cable and put it back..
Old 10-18-2012, 20:22   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Check this: Perfect Solution for No Security Dongle Detected & HTI Drivers, will solve it.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-19-2012, 06:31   #5 (permalink)
Member: 1745727
Sonork: 100.1617904
Thanks Meter: 65
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
br that will windows xp service pak3 but i will using windows 7 32bite pls chek this and help me
Old 10-19-2012, 06:45   #6 (permalink)
Member: 1745727
Sonork: 100.1617904
Thanks Meter: 65
Old 10-19-2012, 07:31   #7 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,949
Sir, wait, I call my 12 years old nephew and ask him to explain you how to install a driver.
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
Old 10-19-2012, 16:35   #8 (permalink)
Member: 1745727
Sonork: 100.1617904
Thanks Meter: 65
BR,
Manole
Old 12-11-2012, 13:41   #9 (permalink)
Member: 1851591
Hello, my hti box green functionally with MobileEx 3.5 rev 1.6, but, after install MobileEx 3.5 rev 2.4 - No Security dongle... the drivers in win 7 32bits are [HTI Flasher Interface(WinUSB), HTI SmartCard Reader(WinUSB), MXKey SmartCard], if restore version rev 1.6 is normal functionally. Have note that while initialize Mob.rev2.4 is send a reset pulse in HTI and while they reset mobileEx no identify also win7 last time in reinstalation drivers, and MobileEx rev 1.6 no send reset pulse and MobileEx rev1.6 found HTI serial normal. I need from help, and sorry my bad english.
Old 12-11-2012, 14:13   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
You're trying to Cross Install Ver3.5 Rev2.4 on Very Old Version,
So you only need to Delete MobileEx Folder manually after uninstalling,
Then Install Latest Version, will have to Sign Application,
If problem persist, then check here: Perfect Solution for No Security Dongle Detected & HTI Drivers
BR,
ZUBER
Old 12-11-2012, 16:25   #11 (permalink)
Member: 1851591
Friend, I think is a new programming file MobileEx.lib due to HTI box is disconnected during startup software MobileEx rev. 2.3 and 2.4, when reinstall version 1.6 over it works normal, but if you re-install version 2.4 no longer recognizes the HTI, I noticed that when the sofware MobileEx rev 2.4 initializes it sends a reset pulse and the box restarts as if I had unplugged the box and plugged in usb port, windows 7 takes 10 seconds to reinstall the drivers and software MobileEx not expect the box to reinstall, so it does not recognize, then reinstall the version rev1.6 if it works normally does not disconnect the box during MobileEX software startup and usually recognizes rev1.6. I'm using Windows 7 32bit and drivers [HTI Flasher Interface (WinUSB), HTI Smartcard Reader (WUDF) and SmartCard MXKey] and the MXKey works normally, only the HTI box restarts during startup MobileEx rev2.4. Please excuse my bad english.
Old 02-02-2013, 23:25   #12 (permalink)
Member: 357429
Same Problem here.....
Pls Help me....
Page generated in 0.31142 seconds with 7 queries
