07-08-2013, 21:08 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: iran
Member: 303488 Status: Offline Thanks Meter: 208 | pls help i buy new hti orange box same like update error Waiting for HTI in boot mode ... Reinitializing HTI ... » End transaction (status: 12, Failed to open device.) pls help i buy new hti orange box same like |
07-08-2013, 21:23 | #2 (permalink) |
Member: 303488 Status: Offline Thanks Meter: 208 | Waiting for HTI in boot mode ... » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 01.09 Serial: 01013C9B Receive firmware from server ... SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.3 Firmware version on server: 00.50 changes: added: boot mode switch function improved: serial and flash bus communication routine added: dct4 product data calc algorithm added: broadcom sec.repair algorithm minor bug fixed. Received buff checksum verified OK. Updating HTI firmware, please WAIT ... » End transaction (status: 15, Failed to prepare write flash.) |
07-09-2013, 07:30 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
This Error due to Transmission problem, TX connection Error, Check or change Cable connected to Box, use different USB Port, Even check Antivirus Firewall, sometimes create from here too, Post reply if not solve. BR, ZUBER | |
11-21-2013, 09:45 | #6 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Nepal
Member: 1294102 Status: Offline Sonork: 100.1655641 Thanks Meter: 79 | mx box orange not detected.......... i am using mx box orange....... it was working fine but i updated hti box then the error occurs. after that my mx box is not detected it only detected as HUMAN INTERFACE DEVICES.... computer only sounds todo todo todo todo ........ what to do..... i formated my pc, and reinstalled it but the problem is same. I am using mobileEx 3.5 (rev2.6) |
11-21-2013, 22:46 | #8 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
Try to update first your HTI box, the process as simple as : - Do not plug hti to pc - Install 3.5rev2.6 - Open mobileex.exe, ignore no dongle detection - Press update HTI, plug HTI to usb immediately. (internet connection needed) - Proceed with driver installation after update FW is done. | |
01-24-2014, 19:21 | #12 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
and instead with my big surprise I fixed it fixed following your procedure. The problem came during a "upgrade" routine.... getting an error regarding deleting the flash. it ended up with red and orange led blinking alternatively. since i've read a lot of people has the same problem.. why don't you guys read the forum? I hope other people will be able to fix their boxes. Cheers X4ce | |
