08-27-2011, 04:15 | #1 (permalink) |
Junior Member Join Date: Jul 2011 Location: Cambodia
Member: 1624477 Status: Offline Sonork: 1606201 Thanks Meter: 1 | Pls help me N73 phone startup failled contact the retailer (ANSWERED) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35897301309734-6 Product code: 0529607 Battery voltage: 4817 mV, current: 27 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358973013097346 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN I try to repair by this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset but the problem still the same pls help me |
The Following User Says Thank You to po seyla For This Useful Post: |
08-27-2011, 04:32 | #2 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
PPm auth. Cheeck ( RF BB from Server) then click write . all ok | |
The Following 2 Users Say Thank You to maxpro12 For This Useful Post: |
08-30-2011, 15:45 | #4 (permalink) |
Registered User Join Date: Jan 2009
Member: 952508 Status: Offline Sonork: 15432 Thanks Meter: 8 | Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35897301309734-6 Product code: 0529607 Battery voltage: 4817 mV, current: 27 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358973013097346 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN I try to repair by this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset |
