06-04-2012, 11:32 | #1 (permalink) |
Insane Poster Join Date: May 2008 Location: Johanesburg south africa
Member: 777161 Status: Offline Thanks Meter: 1 | pls help nokia 5130c DCC corrupted warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF01035424, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352700043004745 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-04-2012, 11:59 | #4 (permalink) |
Member: 777161 Status: Offline Thanks Meter: 1 | this is the logs Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35270004300474-5 Product code: 0582675 Battery voltage: 4683 mV, current: 155 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF01035424, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352700043004745 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN No dcc found from datapackage directory. Scanning dcc on local storage ... Trying to request configuration file NIMMIIIIRRFF01035424,XXXXXX from server ... SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 Camera Configuration file written. Verifying DCC data ...OK. |
06-04-2012, 12:38 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | OK write this file by manually & post result. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-03-2012, 18:17 | #8 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
There is no such DCC file in Data Package Directory, Write my above DCC file, If not solve, then remove Camera, clean it & it's Connector, At the last change Camera. BR, ZUBER | |
