08-09-2011, 05:34 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | plz chack this? (ANSWERED) Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F0F12C Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.5 EBL version : Quantum_Bootloader_2.5_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbps Flash ID: 0089 8982 [Intel NU48F512,512 Mbits] Processing file: rm607__05.40.mcusw Downloading item CODE:rm607__05.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.375 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.500 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.375 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.343 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 27.219 s Checksum verified (0xC075) Processing file: rm607__05.40.ppm_c Downloading item CUSTackage_c.ppm_ebl_psi.fls, num block: 1, size: 3.72 MB Erasing area 0x41C00000-0x41FB8A26 ...OK Programming completed in 4.313 s Checksum verified (0x376C) Processing file: rm607__05.40_004.image_c_ctv_uk_9f3t8 Downloading item CUSTackage_c_ctv_uk.image.fls, num block: 1, size: 11.50 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 13.407 s Checksum verified (0xA06F) Total time for flashing process(boot+erase+write) was 7 min 0.422 s Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F0F12C WriteDevice failed: A device attached to the system is not functioning Verifying communication to device... ERROR: Could not verify communication ! Phone type: RM-607 (C1-01) SW version: V 05.40 01-06-11 RM-607 (c) Nokia Imei plain: 35702104852941-1 Product code: 059G896 Battery voltage: 3980 mV, current: 110 mA Language Pack: - not available. Imei net: 35702104852941 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
08-10-2011, 08:40 | #2 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C08541A4 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm576_062.001_prd.core.fpsx [BB5,XSR 1.6] size: 85.39 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 02C00112776B0E49445CFE386814701A8F68048E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0040 - 0000 0031 [Toshiba NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35339004100135_CE RT.rpl). CMT PAPUBKEYS HASH: B1302F79239A2431E816565B36374B1F676A23AC Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 177.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0B53FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: B1302F79 [RAP Certificate 171 v.1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 16.703 s Processing PPM file: rm576_062.001_10.01_MEA_A_prd.rofs2.fpsx [BB5,XSR 1.6] size: 37.85 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 47.25 MB CMT FLASH,MuxOneNAND area [07800000-0A73FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.313 s Processing PPM file: rm576_062.001_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.95 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A740000-0B53FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.031 s Processing CNT file: RM576_ENO_10w40v0.A40.fpsx [BB5,XSR 1.6] size: 2.28 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.453 s Processing CNT file: rm576_062.001_URed006.000_prd.uda.fpsx [BB5,XSR 1.6] size: 3.54 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 65 MB CMT FLASH,MuxOneNAND area [0B540000-0F63FFFF] Flash programming ... Programming completed in 1.062 s Total time for flashing process(boot+erase+write) was 38.609 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 Verifying communication to device... ERROR: Could not verify communication ! Phone type: RM-576 (Nokia 6700s) SW version: V ICPR82_10w34.4 09-12-10 RM-576 (c) Nokia Imei plain: 35339004100135-3 Product code: 0589498 Battery voltage: 3856 mV, current: 178 mA ApeCoreSw: 062.001 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353390041001353 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.937 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.734 s |
New to all this (about 1 hour) :) | Mark UK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-01-2010 09:01 |
try this for nokia 5.36 | BELY | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-28-2000 00:59 |
READ this IGOR_M!!!!!!!!!!!!! | nightxyz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-04-2000 04:49 |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
Plz help with unlock NOKIA 6110 2lock | henr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:29 |
