Old 03-06-2010, 10:56   #1 (permalink)
rajan nishchal's Avatar
Member: 75612
Thanks Meter: 1,427
plz check i have 2 set RM-436 (Nokia 7210 Supernova)
plz check i have 2 set RM-436 (Nokia 7210 Supernova) not able to repair SIMLOCK invalid!
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35196203408643-5
Product Code: 0572571
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[0B900015DBFB7C568C5E332CA0D64D617788BF95] ...
Calculating SIMLOCK using security server ...
Completed in 1.671 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_351962034086435_SIM.RPL"
Updating SIMLOCK...error 0x14
Reading Simlock info ...
Old 03-06-2010, 11:09   #2 (permalink)
Member: 75612
Thanks Meter: 1,427
and cant able to repair sd rpl
Old 03-06-2010, 11:10   #3 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
write full pm with super sd auth and dont skip rewrite simlock option
Old 03-06-2010, 11:12   #4 (permalink)
jhay_12's Avatar
Member: 311499
Thanks Meter: 34
just try to click unlock then post the result...
br,
Old 03-06-2010, 11:17   #5 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
Language Pack:
- not available.
SIMLOCK invalid!
see this guide
(bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>>
repair sd ) now go to pm section only super sd auth betan clik
now selact>> pm lord from file>>pm auth>> write pm
now your fone is ok insha****************
Old 03-06-2010, 12:28   #6 (permalink)
Member: 75612
Thanks Meter: 1,427
Product Code: 0566807
Language Pack:
- not available.
SIMLOCK invalid!
Old 03-06-2010, 12:29   #7 (permalink)
Member: 75612
Thanks Meter: 1,427
Originally Posted by naveedbutt View Post
see this guide
Calculating SUPERDONGLE using security server ...
Completed in 3.484 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_351962034086435_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Old 03-06-2010, 12:55   #8 (permalink)
Registered User
Member: 419331
Thanks Meter: 101
i have same problam i do all processer but no solution
Old 03-06-2010, 13:05   #9 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
maybe this error from server becoz server down
Old 03-06-2010, 13:22   #10 (permalink)
Member: 151576
Sonork: 100.1602537
Thanks Meter: 58
Put a tick mark in (PA sl2) check box,then update sim lock.
Old 03-06-2010, 13:25   #11 (permalink)
Registered User
Member: 419331
Thanks Meter: 101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1630020507045950D7BD44C2FA9255E406366F2E
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35931002480087
Original Product code: 0572571
Bluetooth ID: 0024046DE66F
Imei plain: 35931002480087-2
Product Code: 0566806
Language Pack:
- not available.
[This phone have PM308 protected, SD security in not restorable.
[/COLOR]SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359310024800872
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
I DO ALL PROCESSER BUT NO SOLUTION
Old 03-06-2010, 13:31   #12 (permalink)
Member: 75612
Thanks Meter: 1,427
SAME AFTER TICK ON PA_SL2
Completed in 1.688 s
Old 03-06-2010, 13:37   #13 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
TRY TO FLASH URE PHONE AND REPAIT THE SL DATA AGAIN
WBR
sahil2000ind
Old 03-06-2010, 14:03   #14 (permalink)
Member: 151576
Sonork: 100.1602537
Thanks Meter: 58
Check here,
http://forum.gsmhosting.com/vbb/show...8&postcount=22
Old 03-06-2010, 14:15   #15 (permalink)
Member: 75612
Thanks Meter: 1,427
I DO SAME U TOLD ME BUT RESULT SAME
Completed in 1.359 s
Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 04.86 08-08-08 RM-436 (c) sanjayvikas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-03-2010 00:15
RM-436 (Nokia 7210 Supernova) >>> possible to unlock?? mantok MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 12-07-2009 13:31
Page generated in 0.28492 seconds with 9 queries
