Plz help. Can hd5870 crossfire in windows xp 32 bits? Hi, With a single HD 5870 i got code found for nokia 2700c in windows xp 32 bits with time/salt ~ 80 secs. ( took ~4 days and code found at 44% with radom salts) To increase the speed, i setup a new pc with 2x HD5870 in cressfire and run with windows 7 64bits. Time/salt ~36 sec. However, after 4 days of waiting to unlock another 2700c, i ended up with no code found. Thinking of the bruceforce is not function probably under windows 7, i just reinstall the pc with windows xp 32 bits. However, i could not make 2 gpu running at the same time although i did tick the crossfire option in catalyst. (under MSI afterburn, only 1 gpu is worked). Could anyone help PLEASE... (which version of catalyst should i use?) Cheers, Lee |
lucky or unlucky ,this solution not 100% ok for sl3 ,problem code not found not from window or driver etc,it from ishashgpu ,what version u use in software until now ,8 phone suscess with hộp cơn lốc, 2 not found from mx key ,u can see how many problems when search this forum ... and hi vọng anh em cầm cự được trong cơn lốc giá cả, good luck to all |
