06-06-2010, 06:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: pune
Member: 1263646 Status: Offline Sonork: 1625091 Thanks Meter: 17 | plz help imei ??????6610 ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C32FB7:2984DA60 ASIC type: 2 UEM Imei: Empty Flash Imei: 35296000695978 Investigating flash imei ... Looking for backup for this phone ... Backup found, restoring to the phone ... ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C32FB7:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: NHL-4U (Nokia 6610) SW Version: V 5.52 19-09-03 NHL-4U (c) Nokia. Imei plain: ??????????????-? Imei OTP: 31A8831238A269 Product Code: 0509499 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: W Language Pack: English,Chinese S,Chinese T,Hindi,Bahasa Ind Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCKLIB VERSION 2.26 Counter: 0/3, 0/10 CONFIG_DATA: 717C08A778E1BC33 PROFILE_BITS: 2753112CB0574114 SIMLOCK_DATA corrupted! i also try online logger but error msg comes access violation how to solve masters plz help |
06-06-2010, 06:39 | #2 (permalink) |
Member: 1263646 Status: Offline Sonork: 1625091 Thanks Meter: 17 | after write rpl this plz help VM_SODHA sir , ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C32FB7:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Operation done with error. |
06-06-2010, 07:44 | #3 (permalink) |
Member: 1263646 Status: Offline Sonork: 1625091 Thanks Meter: 17 | after write rpl from potato box log Power on the phone... Reading imei... ??????????????? Opening RPL file... Inspecting... IMEI: 35296000695978 Booting phone... MCU ID: 0x1120 Sending algo... Algo is ready... Writting UEM... UEM Write OK. FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 5.52 19-09-03 NHL-4U (c) Nokia. HW version: 0660 PCI version: 0 UEM version: 8 UPP version: 4384 RFIC version: 0203 DSP version: V4.61 LCD version: SED15G10 PPM version: V 5.52 19-09-03 NHL-4 (c) Nokia. W Production serial number: MHD552976 Product code: 0509499 Module code: 0 Basic production code: 0507780 Flash code: 0 Order number: 0 Product specific data: 0 Long production SN: 0 ATO: 0 Default SN type: 0 IMEI plain: ??????????????? IMEI spare to net: FA FF FF FF FF FF FF 0F IMEI SV to net: F3 FF FF FF FF FF FF 5F F3 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 5013663745 Phone type: NHL-4U, Software version: 5.52, Language Pack: W User code: 12345 |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
