Old 01-31-2010, 14:07   #1 (permalink)
samgsm's Avatar
Member: 478781
Thanks Meter: 44
plz help {manole} 7210c contact service
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002593168-4
Product Code: 0572571
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359310025931684
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 122.168.220.98
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
what to do
Old 01-31-2010, 14:12   #2 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Arrow
Go service tab > Click Quick Fix > BB5 SW Downgrade Fix > click Do select jobs
Old 01-31-2010, 14:16   #3 (permalink)
samgsm's Avatar
Member: 478781
Thanks Meter: 44
thx for reply but prob same
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 01-31-2010, 14:21   #4 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
Don't worry goto service> PM> PM Auth > after Authorize success write a good PM except 308 simlock area, as ur info says SECURITY_TEST failed!
all will be fine .
regards
rockgsm
Old 01-31-2010, 14:26   #5 (permalink)
Member: 1221739
Sonork: 5656
Please RPL made up I'll help you spike it.
Old 01-31-2010, 14:26   #6 (permalink)
Member: 1133675
Sonork: 100.1604417
Thanks Meter: 18
Write modified PM with SX4,your phone will be OK
Old 01-31-2010, 14:37   #7 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Check this out
Old 01-31-2010, 14:39   #8 (permalink)
Member deceased !!
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Thanks Meter: 1,348
i have same problem,when repair sd with ub show sd repir ok credit gone but can't connect sx4.plz help me
Old 01-31-2010, 14:50   #9 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Contact service
post ur logs here by Mx Key
Old 01-31-2010, 15:55   #10 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
You had ST_Security_failed in phone selftest and It can be solved by two ways.
- Write good PM file field 1 and 309
- Phone has not sync or not available CCC and HWC data. So you need to rewrite from working phone. It works sometime.
CCC - Common Configraution Certificate
HWC - HardWare Certificate
B,R.
KABO
Old 01-31-2010, 23:40   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
then GOTO UB section,cos our tools can't repair
if already fix SUPERDONGLE by other device.
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
what to do
if your phone already fix superdongle by other device,
our SX-4 server can't authorize that
continues your JOB , with your repair superdongle device
br,
plz help me 6300 contact service amer_a_82 Nokia Base Band 5 ( BB-5 ) 2 11-12-2009 12:37
Please Help Me 7210c Contact Service Not Solved swechacnu Nokia Base Band 5 ( BB-5 ) 10 08-26-2009 13:08
Please Help Me 7210c Contact Service Not Solved swechacnu Nokia Base Band 5 ( BB-5 ) 0 08-06-2009 11:31
PLZ Help!!! Nokia 1110i contact service muhammadjon_25 Nokia Digital Core Technology 4 ( DCT-4 ) 1 12-10-2006 09:13
Page generated in 0.25442 seconds with 10 queries
