Old 08-03-2010, 08:58   #1 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
plz help me with 1208 rpl
i am trying to write rpl for 1208
here is log what is wrong plz help me
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 008C93F1A3BDA66
ASIC type: 11
UEM Imei: 35318503116053
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35318503116053.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei (OTP) ...failed
Phone Type: RH-105
SW Version: V 5.91 27-03-09 RH-105 (c) NMP
Imei plain: ??????????????-?
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000010000
SIMLOCK_DATA corrupted!
Old 08-03-2010, 09:02   #2 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
go to dct4> ime & security > online logger> dct4 ime clk
set will be ok
good luck
Old 08-03-2010, 09:43   #3 (permalink)
Member: 1343046
Thanks Meter: 8
Full erase - write lowest version - write back your rpl calculation - write pm and unlock
Originally Posted by rana_jee
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\3531850311605 3.RP L"
Old 08-03-2010, 10:28   #4 (permalink)
Member: 392149
Thanks Meter: 199
If u have RPl & not done write rpl then erase ur fhone flash it and
try to write rpl ur fhone ll be ok soon
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.16493 seconds with 9 queries
