04-05-2010, 17:09 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: B D S Age: 40
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | plz help me mx key team Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.060 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.062 s |
04-05-2010, 19:11 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,944 | Quote:
BR, Manole | |
The Following User Says Thank You to MANOLE For This Useful Post: |
04-06-2010, 12:10 | #7 (permalink) |
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | HELP? WHEN I GOING TO FALASH ANY PHONE GIVE THIS ERROR ...I GOT THIS PROBLEM WHEN I Updater_V4 TNX Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.032 s |
04-07-2010, 16:53 | #8 (permalink) |
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | HELP MX KEY TEAM HOW CAN I SOLV THIS PROBLEM Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.032 s |
04-08-2010, 10:15 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Your box damaged by Potato Man Raskal I have made warning and advice long time ago: http://forum.gsmhosting.com/vbb/f550...update-957126/ http://forum.gsmhosting.com/vbb/f550...rmware-925332/ The box you have in your hand is a Potato interface what you calling it JAF it belong to Gsm Traders LTD. from Hong Kong, Raskal company wich have the trademark for the names JAF. Go to Potato Box forum and ask for support. J.A.F - Just Another Flasher - GSM-Forum Here is MXKEY support forum. Sorry friend, Topic closed acording to mxkey forum rules: http://forum.gsmhosting.com/vbb/f550...hreads-967354/ br, |
3110c contact service.PLEASE help me MX-KEY team | VIBINDAS_INDIA | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 22 | 06-19-2011 13:42 |
Plz Plz halp me MX-Key team | kabul | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-28-2010 14:07 |
Plz help me mx key team[SOLVED] | askaralikp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-10-2010 08:12 |
Help me MX-KEY team & all mambers | Mallick Manzil | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 07-23-2009 07:19 |
Plz help me MX KEY TEAm | amar181 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-30-2009 19:34 |
