10-28-2011, 14:09 | #1 (permalink) |
Junior Member Join Date: Dec 2009 Location: GAZIPUR
Member: 1179001 Status: Offline Sonork: no Thanks Meter: 0 | plz help me nokia 1200 contact service mxkey flash info MXKEY Serial: [FT SCR2000 0] - C0842E5B Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084EDB3A3BDA66 ASIC type: 11 UEM Imei: 35684502062028 Flash Imei: 35684502062028 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35684502062028_BA CK.rpl" Processing MCU file: rh99_06.000 [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084EDB3:2984DA60 Area [01000000-0100FFFF] erased in 0.610 s Area [01010000-013AFFFF] erased in 36.734 s Area [013B0000-013EFFFF] erased in 2.906 s Area [017C0000-017EFFFF] erased in 0.172 s Area [01FC0000-01FEFFFF] erased in 0.172 s Flash programming ... Programming completed in 23.109 s File Processed in 1 min 27.500 s Processing CNT file: rh990_nai6.00ej [DCT4,DCT4 ALGORITHM] size: 109.24 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084EDB3:2984DA60 Area [01380000-013AFFFF] erased in 1.937 s Flash programming ... Programming completed in 1.218 s Content extract fail, continue anyway ... File Processed in 1 min 3.359 s Processing PPM file: rh99_06.00ej [DCT4,DCT4 ALGORITHM] size: 1.15 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084EDB3:2984DA60 Area [01240000-0124FFFF] erased in 0.625 s Area [01250000-0137FFFF] erased in 12.250 s Flash programming ... Programming completed in 11.765 s File Processed in 34.750 s Total time for flashing process(boot+erase+write) was 3 min 5.625 s |
10-28-2011, 14:37 | #4 (permalink) |
Member: 1179001 Status: Offline Sonork: no Thanks Meter: 0 | hwk ufs3 flash info 1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84BB3D94334D48A177BBCCB94F Decoded MSID: 3E4EBAE9-0084EDB3-A8000000 Encoded FAID: 54B4BF30-D3E5B191-033A6454 IMAGE: rh99_05.910 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:39 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:19 IMAGE: rh990_nai5.91if Area1: 0x01380000-0x013AFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
10-28-2011, 14:41 | #5 (permalink) |
Member: 1179001 Status: Offline Sonork: no Thanks Meter: 0 | plz help me nokia 1200 contact service hwk ufs3 flash info 1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84BB3D94334D48A177BBCCB94F Decoded MSID: 3E4EBAE9-0084EDB3-A8000000 Encoded FAID: 54B4BF30-D3E5B191-033A6454 IMAGE: rh99_05.910 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:39 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:19 IMAGE: rh990_nai5.91if Area1: 0x01380000-0x013AFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
10-28-2011, 15:12 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | bro try with unlocking the phone it will solve ur problem if not then erase with ufs then write flash and write full pm then do ui deafult then unlock it will solve your problem if not solve then its hardware problem. |
The Following User Says Thank You to jawedjp For This Useful Post: |
10-28-2011, 15:22 | #12 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | use easy cable and reflash it. Plz.first check 4leg bsi resister of local mode. if not present, then make jumper on both leggs. |
The Following User Says Thank You to amn32 For This Useful Post: |
