02-15-2010, 13:01 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 189604 Status: Offline Thanks Meter: 3 | plz....n96 flashing error Version from file: 30.033 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 1855DB793A946715F1D8EE5BB0A39916522B1D7F ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 06D0010D19AE0158628AFD7597C873E0F414FFA8 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 loader not responding (0910000000B172) Read Certificate failed. NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK WLAN_DATA saved OK and then viewed the message : cannot creat file "c:\mobileEx\3.3\<". The filename,directory name, or volume label syntax is incorrect im use tornado box Last edited by hitman1986; 02-15-2010 at 13:08. |
02-15-2010, 14:38 | #8 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | n 96 Quote:
The Following User Says Thank You to shahid41 For This Useful Post: |
03-27-2010, 15:57 | #10 (permalink) |
Junior Member Join Date: Sep 2007
Member: 589070 Status: Offline Thanks Meter: 0 | guys i am having the same problem. can anybody help? Read Certificate failed. NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK and then viewed the message : cannot creat file "c:\mobileEx\3.3\<". The filename,directory name, or volume label syntax is incorrect |
03-27-2010, 18:20 | #11 (permalink) |
Member: 589070 Status: Offline Thanks Meter: 0 | answering my own query. i was making mistake. i set my own directory path in module and that is why i was having problem. leave all mobile ex setting by default and it would be okay i believe. flashed and unlocked one phone..nokia 5220 thanks anyway |
n96 flashing error.. | zulu land | MT-BOX | 2 | 05-13-2009 12:06 |
N96 Flashing Error : | Sydney_Unlocker | Cyclonebox | 28 | 04-29-2009 10:54 |
N96 flashing error | brane_obrad | Universalbox | 2 | 10-13-2008 19:30 |
