Old 02-09-2010, 19:31   #1 (permalink)
Member: 438721
Thanks Meter: 4
PLZ need Help (SUPERDONGLE_KEY) N958GB
How to Slove this/
Phone Type: RM-320 (Nokia N95 8GB)
SW Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia
Imei plain: 3569**********
Product Code: 0558166
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3569*********
Version: SIMLOCK SERVER
Provider: SFR, Country: France
Counter: 0/3, 0/10
CONFIG_DATA: 2081000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN, DATA=20810F
BLOCK 2: 1=OPEN, DATA=20810F
BLOCK 3: 1=OPEN, DATA=64710F
BLOCK 4: 1=OPEN, DATA=64710F
Old 02-09-2010, 19:37   #2 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
1. Repair SD
2. Super SD Auth, then write PM1 and PM309 regarding connected phone model
The Following User Says Thank You to mobile_sos For This Useful Post:
Old 02-09-2010, 19:41   #3 (permalink)
supportallgsm's Avatar
Member: 194074
Sonork: 100.1574944
Thanks Meter: 162
1. Repair SD
4. Write PM with SD auth
Old 02-09-2010, 19:42   #4 (permalink)
Member: 438721
Thanks Meter: 4
Still the Some Bro..
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 11.422 s
RPL saved to "E:\MX_KEY\3.3\data\backup\BB5_RM-320_356983011351118_SD.RPL"
Updating SUPERDONGLE_KEY ...error 0x0
Old 02-09-2010, 19:51   #5 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
do backup.
try with erase metods before flash
then retry your JOB
before erase please do backup
Old 02-09-2010, 20:02   #6 (permalink)
Member: 194074
Sonork: 100.1574944
Thanks Meter: 162
this cable Problem ........
The Following User Says Thank You to supportallgsm For This Useful Post:
Old 02-10-2010, 01:29   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
You got Only NPC? NO PROBLEMO!
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-10-2010, 22:50   #8 (permalink)
Member: 572236
Thanks Meter: 10
Hi there
I repaired a N95 8GB tonight with the same problem.
Try writing the saved RPL (RPL saved to "E:\MX_KEY\3.3\data\backup\BB5_RM-320_356983011351118_SD.RPL") and then write good PM 1 and 309 using Super SD Auth and your problem should be solved.
PLZ... Need help...! k700 / T610 anonyme_net Sony Ericsson 0 06-24-2006 02:20
Plz Need Help With Philips 855 decoder5000 Philips 1 11-06-2005 18:35
sms and bt problem on P910i plz need help? .::Moby World::. Sony Ericsson 3 10-23-2005 21:48
plz, need help at S40 sebman NON Siemens Brand (ODM Phones) 0 09-10-2003 13:52
Plz need help for nokia 8310 no vibratand not ring CHATAR Nokia Digital Core Technology 4 ( DCT-4 ) 4 03-18-2002 22:29
Page generated in 0.30246 seconds with 8 queries
