Old 06-25-2010, 04:13   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
how to do with 2760 after change UEM, no w lcd is blank
i already change UEM, but lcd is blank when power on
how to write rpl file for a 2760? can i write back the original rpl that mxkey backup which is 3kb ? pls assist.
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 0017FD5FA3BDA66
ASIC type: 11
UEM Imei: Empty
Old 06-25-2010, 05:36   #2 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
ASIC type: 11
UEM Imei: Empty
u have to write rpl to OTP area too
what was the problem which leaded to change uem ?
u have rpl backup with old uem imei ?
YOU HAVE TO FLASH THE SET FIRST
then rpl including OTP
The Following User Says Thank You to neilthirumuttam For This Useful Post:
Old 06-25-2010, 06:51   #3 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
battery become pregnant and baterry not lasting.
phone is warm when using it, i check but there is no short circuit PA is ok. but i can feel warm in the uem and cpu. I 1st try to chage the CPU, but phone become less warm, so i try 2nd time to change the uem to observe first, but it won't allowed me to write rpl
i try to click backup rpl but show this list index out of bound (0)
Old 06-25-2010, 10:29   #4 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Note down IMEI from phone back label and manually calculate RPL for this.
Now write calculated RPL. If UEM is old one, just let MXKey to calculate it automatically.
Br,
Shadab Ahmad
Old 06-25-2010, 10:35   #5 (permalink)
Member: 1326991
Sonork: 420anis143
hi, not related to the above but does anyone know how to fix the ringer in a Nokia 3555?? highly appreciate the help...
Old 06-25-2010, 11:36   #6 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Br,
Shadab Ahmad
how to manually calculate? pls guide me step by step. t q
Old 06-26-2010, 09:53   #7 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Goto Service > Imei & Security > Online Logger.
Press Login.
Check Calculate Manually.
Now enter IMEI, select ASIC and press Request RPL.
Now write received RPL.
Br,
Shadab Ahmad
Old 06-26-2010, 12:19   #8 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
brother . thank you very much
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.19287 seconds with 9 queries
