Old 07-11-2010, 15:41   #1 (permalink)
Arjun mishra's Avatar
Member: 426107
Thanks Meter: 64
pmm and SD authrozitaion failed on N73
here is the log
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia.
Imei plain: 35275701580950-1
Product Code: 0529785
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352757015809501
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia.
Using cached productData[1580021930900154A0BF0130FCB53EDF76D0AE9C] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Elapsed: 16.438 s (session timeout out after 3 second)
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 218.248.64.235
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Retrying ...
Authenticating using [MX] security server ...
The Following User Says Thank You to Arjun mishra For This Useful Post:
Old 07-11-2010, 15:48   #2 (permalink)
Raju0657's Avatar
Member: 882346
Sonork: 100.1597360
Thanks Meter: 54
it would problem of ur internet provider
Old 07-11-2010, 15:52   #3 (permalink)
Member: 205474
Sonork: 100.1585171
Thanks Meter: 97
re repair sd y r prob will be solved
Old 07-11-2010, 15:58   #4 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
Wats ur problem
every thing showing ok in logssssssssss
Old 07-11-2010, 16:10   #5 (permalink)
Member: 426107
Thanks Meter: 64
i want to write pm but
this is the problem..
sd already is valid
Old 07-11-2010, 16:40   #6 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
sd already is valid
This problem come from internet connection between your provider and
Alim MXKEY server based in Indonesia.
BR,
Manole
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.22051 seconds with 9 queries
