04-27-2010, 17:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Post Here For Any Kind Of Help For MX Key Mxkey All Kind Of Help By basitmemon786 Hi Dear Friends I Will Try To Help Mxkey Users To Solve Their Problems ... If You Having Problem Please Do Not Create More threads And Dont Spam Post Here I Will Try To Solve Your Problem Will Be Solved Soon As Possible Last edited by GsmUniversal; 04-27-2010 at 17:28. |
The Following 14 Users Say Thank You to GsmUniversal For This Useful Post: |
04-27-2010, 17:43 | #2 (permalink) |
Freak Poster Join Date: Mar 2010 Location: hyderabad
Member: 1257171 Status: Offline Thanks Meter: 86 | Mxkey All Kind Of Help By basitmemon786 Hi Dear Friends I Will Try To Help Mxkey Users To Solve Their Problems ... If You Having Problem Please Do Not Create More threads And Dont Spam Post Here I Will Try To Solve Your Problem Will Be Solved Soon As Possible thanx brother |
04-27-2010, 17:49 | #3 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
Here is the first case for you. Got this error while trying to flash 3120c :- Quote:
The Following User Says Thank You to adnann5 For This Useful Post: |
04-27-2010, 18:16 | #4 (permalink) | |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
now the solution for ur problem do try this.. YouTube - ChangeFlashLoader.wmv br, basitmemon from mxkey.. | |
The Following 5 Users Say Thank You to GsmUniversal For This Useful Post: |
04-27-2010, 18:51 | #6 (permalink) | |
Current interface " UFS3 Sara Soft is supported for new security protocol" what about this?? Br | |
04-27-2010, 18:54 | #7 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | it is so simple dear becuase of power compatibily and other reason it says this... actually now potato box is also not good compatible with mxkey thats why manole and coders of mxkey creates new interface it will soon launch for us... |
04-27-2010, 18:57 | #8 (permalink) |
Junior Member Join Date: Nov 2007 Location: thainguyen
Member: 633136 Status: Offline Sonork: [email protected] Thanks Meter: 5 | xin giúp tôi 5800 unlock Root key hash: 479c6dde3942e12c429c1d6aded80371 |
04-28-2010, 01:43 | #10 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Sydney, Australia
Member: 710795 Status: Offline Thanks Meter: 18 | Quote:
http://forum.gsmhosting.com/vbb/f550...-mxkey-973601/ | |
04-28-2010, 04:23 | #11 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Inside Boxes
Member: 228871 Status: Offline Thanks Meter: 43 | Quote:
http://forum.gsmhosting.com/vbb/f550...-error-986768/ | |
04-28-2010, 05:20 | #12 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | @basitmemon786 sir today i have got a 1200 contact service set. i flashed the phone with 6.0 ver.flashing successful but contact service not gone. can u please guide me. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12843(27-04-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C7C0B6A3BDA66 ASIC type: 11 UEM Imei: 35685002****** RPL saved to "C:\mobileEx\3.3\data\backup\35685002******_BACK.r pl" Processing file: rh99_06.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C7C0B6:2984DA60 Area [01000000-0100FFFF] erased in 0.703 s Area [01010000-013AFFFF] erased in 35.438 s Area [013B0000-013EFFFF] erased in 2.719 s Area [017C0000-017EFFFF] erased in 0.125 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Programming completed in 22.047 s File Processed in 1 min 9.594 s Processing file: rh990_nai6.00mg as CNT [DCT4,DCT4 ALGORITHM] size: 151.84 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C7C0B6:2984DA60 Area [01380000-013AFFFF] erased in 1.891 s Flash programming ... Programming completed in 1.531 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 17.922 s Processing file: rh99_06.00mg as PPM [DCT4,DCT4 ALGORITHM] size: 987.43 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C7C0B6:2984DA60 Area [01240000-0124FFFF] erased in 0.640 s Area [01250000-0137FFFF] erased in 11.672 s Flash programming ... Programming completed in 9.453 s File Processed in 32.172 s Flashing completed in 2 min 40.562 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-99 SW Version: V 6.00 30-09-09 RH-99 (c) NMP Imei plain: 3568500219****** Product Code: 0546960 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 35685002****** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 47.781 s self test info.... Uploaded with ImageShack.us |
04-28-2010, 11:17 | #13 (permalink) | |
04-28-2010, 15:20 | #15 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Thread reopened as user request. 1. no tnx post in this thread 2. stay on topic, users with blocked dongles stay away from this (@ Shantobhai) BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
