03-28-2010, 12:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | :::POTATO box problem in flash and bus check but unlock ok:::whats the reason??? result----------- Using device: POTATO FLASHER INTERFACE Interface: POTATO BOX » BOX FW Version: 01.B2 » BOX Authentication ...OK. POTATO FLASHER INTERFACE ready. i select dct4 tab and click bus check(jaf not connect but ufs check ok) result----------------(jaf) Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. when bus check not successfull i click scan. result----------------(with jaf) Phone Type: RM-37 (Nokia 6610i) SW Version: V 4.40 28-10-05 RM-37 (c) Nokia. Imei plain: 35780800303733-5 Imei OTP: 35780800303733 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: W Language Pack: English,Chinese S,Chinese T,Hindi,Bahasa Ind Imei net: 35780800303733 Version: SIMLOCKLIB VERSION 2.28 -fix task:Extended number of TDS-6 boxes Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN now.what is actual problem?????? why unlock+imeirebuiled and another function ok but flashing not.?????? i also try a 1202 same result.buscheck not but scan ok-------RESET ALL OK Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35520203503965-3 Product Code: 0564054 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MS Language Pack: - not available. "C:\Program Files\Nokia\Phoenix\Products\RH-112" folder created. Imei net: 35520203503965 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.296 s I CANNOT FLASH WITH F-BUS CABLE BY JAF AS A INTERFACE BUT I CAN OTHERS WORK WITH F-BUS. FOR DCT4 FLASHING F-BUS MUST NEEDED.IN BB5 WE CAN FLASH BY USB. WHATS THE PROBLEM????? CAN ANYBODY EXPLAIN???? CAN WE CALL, JAF DEAD??? OR HALF DEAD????? WHATS YOUR EXPERIENCE?? POST HERE |
03-29-2010, 06:16 | #5 (permalink) | |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
well, but how i work with your mx-key? you dont have any interface.you use jaf and ufs. jaf box made by other team and you use it as a interface.and now when this box is problem you said go there section? or, you plan a new interface for this reason not care anything ? my box worked well before your new update use(3.3 1.7). batter do something for that. remember you (mx-key) are depend on others team work(for interface) | |
The Following 2 Users Say Thank You to shahinahmed007 For This Useful Post: |
03-29-2010, 07:06 | #6 (permalink) | |
who use your updater his box damaged after use 3.3 1.7 POTATO JAFBox Updater V4 http://forum.gsmhosting.com/vbb/f550...de-6-a-955457/ this is the reson. i use this and my box damaged but my friend not use his box work well. and who only use jaf software,his box not damaged. who use jaf softare and mx-key his box must damaged. so, who are guilty??????? | |
The Following User Says Thank You to shahinahmed007 For This Useful Post: |
03-29-2010, 07:16 | #9 (permalink) | |
only for bb5 can possible for flashing by usb bb5 flashing is not so inportant for mx-key users.because,lot of free tool available for this. for dct4????? f-bus is most important | |
nokia 6060 flshing problem in jaf and ufs stops in the middle of flashing screen shot | mobilecitycbk | Nokia Hardware & Hardware Repair | 8 | 05-28-2009 10:58 |
N70 Dead-flashing In Jaf And Mtbox Ok-but Still In Dead | zone2 | Nokia Hardware & Hardware Repair | 1 | 11-16-2007 20:23 |
7610 Dead-flashing In Jaf And Ufs Ok-but Can Not In Mtbox?-reason | zonetrichur | MT-BOX | 4 | 04-04-2007 10:39 |
Which box is better for IMEI PROBLEM in 1100 and 2300 | celluniversal | GSM Programming & Reverse Engineering | 16 | 01-26-2006 12:20 |
