03-18-2010, 22:50 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | POTATO Fw Updater v4.0 - Solve: "Error opening, The handle is invalid (code: 6)" Using device: JAF FLASHER INTERFACE Interface: POTATO BOX » BOX FW Version: 01.B2 » BOX Authentication ...failed! Error opening ! Last error: The handle is invalid (code: 6) JAF FLASHER INTERFACE disconnected. That means you are using latest MxKey v3.3 revision 1.7 with an JAF box with PATCHED firmware 01.B2 written inside (used Potato Firmware Updater v2.0). Latest release of MxKey solved JAF Box crypted Authentification used by Potato & Co. to "protect" their boxes to no more be able to be used with 3rd party softwares. Now MxKey v3.3 revision 1.7 support well Authentification with original JAF Box firmwares 01.B2 and 01.B4. So, to solve the error described here: The handle is invalid (code: 6) just download POTATO JAF Box Firmware Updater v4.0 from here: POTATO JAFBox Updater V4 and write any ORIGINAL firmware inside your JAF Box. To be able to use latest release with New Flash Protocol, is required to write Original Firmware 01.B4 BR, Manole Last edited by MANOLE; 03-20-2010 at 09:59. |
The Following 187 Users Say Thank You to MANOLE For This Useful Post: |
Need Potato updater v4.0 link, not rapidshare | pnganga | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-26-2010 10:42 |
The handle is invalid (code: 6) | ravi mobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-12-2010 13:33 |
help me pls.how to update v4.0.0 | journeyR | NSPRO | 3 | 08-10-2008 12:20 |
Platinum Clip Update v4.0 Released! | datacablelondon | Data1 Team Products | 7 | 02-17-2005 05:41 |
handle is invalid | Seed_Mobile | WD2 & APE (Symbian Phones) | 0 | 10-14-2004 05:31 |
