prob with 6280...nokia logo and blink dear members ..i have 6280..when i power on then nokia logo come and then set blink three or four times and powered off..and it dont connect ..pls tell me what i do......have change cable aslo..thanks in advance Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Boot error: 02 FF 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
Did you select the correct generation?? Also make sure the test point is clean. Else use usb mode and try to flash again. BR curvenger |
how we use usb mode in mxkey? |
@razisamb For dead usb flashing select nokia usb rom as a interface and do as well as we do normal flashing. But you need to press power on when software ask for waiting for pooling device etc. Let me know anything else want you more. Br. Shashank |
which usb cable is used.....pls explain.. |
flash your phone using cyclone box best tested by me [ALL] Navifirm - Forum Mobiles her is manuel navifirm-0.1-bin.zip download.. flash your phone and enjoy |
@razisamb You can use normal DKU-2 cable for that. Br. Shashank |
