Old 06-28-2010, 15:40   #1 (permalink)
Member: 629860
Thanks Meter: 53
prob with 6280...nokia logo and blink
dear members ..i have 6280..when i power on then nokia logo come and then set blink three or four times and powered off..and it dont connect ..pls tell me what i do......have change cable aslo..thanks in advance
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
Boot error: 02 FF 72 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Old 06-28-2010, 15:54   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Did you select the correct generation?? Also make sure the test point is clean. Else use usb mode and try to flash again.
curvenger
Old 06-29-2010, 05:54   #3 (permalink)
Member: 629860
Thanks Meter: 53
how we use usb mode in mxkey?
Old 06-29-2010, 10:18   #4 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@razisamb
For dead usb flashing select nokia usb rom as a interface and do as well as we do normal flashing.
But you need to press power on when software ask for waiting for pooling device etc.
Let me know anything else want you more.
Br.
Shashank
The Following User Says Thank You to shashankmobile For This Useful Post:
Old 06-29-2010, 13:07   #5 (permalink)
Member: 629860
Thanks Meter: 53
which usb cable is used.....pls explain..
Old 06-29-2010, 13:41   #6 (permalink)
Member: 1322811
Thanks Meter: 46
flash your phone using cyclone box best tested by me
[ALL] Navifirm - Forum Mobiles her is manuel
navifirm-0.1-bin.zip download..
flash your phone and enjoy
Old 06-29-2010, 13:42   #7 (permalink)
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@razisamb
You can use normal DKU-2 cable for that.
Br.
Shashank
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
Page generated in 0.29435 seconds with 8 queries
