12-13-2013, 21:33 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Algeria
Member: 1270831 Status: Offline Thanks Meter: 21 | Proble Restore IMEI Nokia 1280 I need your help to solve this problem.. can't restore IMEI to this phone here the backup here picture for my problem Thanks in advnce..... |
12-14-2013, 09:20 | #3 (permalink) |
Member: 1270831 Status: Offline Thanks Meter: 21 | here is Bus Check Log Code: Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Phone type: RM-647 SW version: V 04.25 04-05-10 RM-647 (c) Nokia Imei plain: ????????000000-0 Product code: 0592307 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Imei plain is invalid !!! SIMLOCK_DATA corrupted! RPL backup |
12-15-2013, 14:17 | #4 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | install my ufs then insert ufs and connect soft with ufs then restore 1000% ok. post result here. |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
