Old 02-10-2010, 15:25   #1 (permalink)
Member: 389266
Thanks Meter: 12
Problem after repair sd
SD PROBLEM AFTER REPAIR
hello friends had a 6131 that goes out every two hours I realized that the SD via UB was corrupt, via mxkey procedure to repair and the problem went well until I made a call.
low battery message appears and shuts down
the battery is full and in good condition, come to prey again and the battery is full again
I feel the same with a 3500 that did REPAIR SD
can happen
Thanks for your help, sorry for my bad English
lucky
Old 02-10-2010, 16:42   #2 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
bro post ur log here......
Old 02-10-2010, 17:01   #3 (permalink)
Member: 255072
Thanks Meter: 42
repair sd then sx4 write full modified pm then simlock rpl
i thing battery is about pm corrupted
its happend with damaged 1-309
6120 after repair sd security test failed problem solved... rickliew MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 04-08-2010 10:25
3110c after repair SD, write RPL problem Options Media Nokia Base Band 5 ( BB-5 ) 1 02-16-2010 15:42
3110c after repair SD write RPL problem Options Media MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 02-15-2010 12:58
n72 help after repair sd security test failed problem akt007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-04-2010 10:20
Still have problem after repair simlock and SD,SECURITY_TEST fail ! wx654242 Universalbox 15 01-16-2010 11:31
Page generated in 0.22499 seconds with 8 queries
