11-18-2010, 01:32 | #1 (permalink) |
Junior Member Join Date: Nov 2010 Location: Poland
Member: 1445459 Status: Offline Thanks Meter: 2 | Problem with flashing NOKIA 2220s (answered) Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\358009033xxxxx_BACK.r pl). Processing MCU file: rm590__09.55.mcusw [DCT4,DCT4 ALGORITHM] size: 11.30 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 Boot error: 03 00 00 72 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 48.437 s Thank's for all suggestions |
11-18-2010, 01:58 | #3 (permalink) |
Member: 1445459 Status: Offline Thanks Meter: 2 | but what i must check ? cable have 5 pins when i clic button SCAN all information about phone he read ok that i think cable is ok. Phone comes in a test mode and local mode with no problem. |
11-18-2010, 08:52 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | have you try to use different flash loader? try to use another one inside config menu. ps. for such phone, i'd prefer to use EF interface with crocodile clip instead of jigs. ps2. nice cam with you there |
11-18-2010, 21:28 | #7 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | i mean this one: untick auto select loader, choose another loader. if still the same, i suspect your cable is the problem. i got no problem at all here on 2220s. use easy flash connector cable, it's covered many dct4. i personally suggest you to get in one, if you didn't. BR |
