GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   MXKEY Nokia Flasher and Unlocker (by Alim Hape) (https://forum.gsmhosting.com/vbb/f550/)
-   -   problem with my mxkey pls help (https://forum.gsmhosting.com/vbb/f550/problem-my-mxkey-pls-help-943021/)
omnitech 03-05-2010 01:32
hi support,
i just got my new mxkey, fully installed but every time i open up the software this message pop up "Obselete USB device driver or may not installed properly. You want to automatically reinstall the drivers?" doesnt matter if i press yes or no it will direct me to the file under your mxkey folder and i select 2.4.16.0UFS2xx then it ask if i want to reboot so i reboot then restart the software but the same message pop up again, also i try to install the driver when this message pop up directly from my sarasoft ufs usb driver folder and this will not solve the problem too.
if i press no to reboot the computer this error pop up in your software
"unexpected error: Access violation at address 100840C0. Read of address FFFFFFFC"
pls advice what need to be install to solve this problem and i know if im not install this driver properly i cant use the ufs interface however at this moment i can use jaf interface with all the application without any problem, thanks in advance!
Andra 03-05-2010 09:04
your need checkup your PC healty :)
how about reinstall windows first ?
br,
Page generated in 0.08478 seconds with 6 queries
