04-01-2010, 11:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Problem Using JAF InterFace With MXKey Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. When I unlock Imei net: 35351402459180 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! PhoneType:RM-305 SwVersion: V 5.91 27-03-09 RM-305 (c) NMP MCU file: rm305_05.910 Trying to find patch position ...OK, case id: 3 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. I updae JAF InterFace update with "POTATO_JAFBox_Updater_V4" I update firmware v01.B4 update but still firmwarev 01.B1 Any idea MXKey Team............. |
04-01-2010, 13:23 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Your box damaged by Potato Man Raskal. I have made warning and advice long time ago: http://forum.gsmhosting.com/vbb/f550...update-957126/ http://forum.gsmhosting.com/vbb/f550...rmware-925332/ Go to Potato Box forum and ask for support. J.A.F - Just Another Flasher - GSM-Forum Here is MXKEY support forum. Topic closed. BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
when we can use jaf feature in mxkey ? | juwanapati | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-12-2010 11:55 |
can i use this program with MXkey ??? | waleed2500 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-27-2010 18:56 |
