07-30-2012, 02:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: VeneZueLa
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | Problem "Waiting camera" with nokia X2-01 ... Help! read here the log info ..... Code: Phone type: RM-709 (X2-01) SW version: V 07.10 28-10-10 RM-709 (c) Nokia Imei plain: 35741004237847-1 Product code: 059F9R0 Battery voltage: 4013 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC00000401022C00, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357410042378471 Version: SIMLOCK SERVER Provider: Telecomunicaciones Movilnet, C.A. , Country: Venezuela (Bolivarian Republic of) Counter: 0/3, 0/10 CONFIG_DATA: 7340600082413968 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=73406F [Venezuela (Bolivarian Republic of) As I can solve this problem ....? Greetings! |
07-30-2012, 02:41 | #2 (permalink) |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | I got a DCC file and try to write it but I got error ... here the log ... Code: Scanning dcc on local storage ... Using dcc local storage at "modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\dcc\NI00BC00000401022C00.dcc". ConfigName: NI00BC00000401022C00 Version: 003.006 Camera Configuration file write failed ! Trying to write DCC as PM ... DCC write as PM failed ! thanks ... |
07-30-2012, 08:44 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BR, ZUBER | |
07-30-2012, 13:12 | #4 (permalink) |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | thanks for reply brother ... and as I tell you that it is not hardware failure as the camera before making the flash worked perfectly .... then I realize it is not hardware ... and the problem is that I also write the configuration files from the camera or the DCC or the PM ... I hope someone help me ... thanks! |
07-30-2012, 14:12 | #7 (permalink) |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | do not quite understand what you say, I think that gives the server to see if it repairs .. . if that this is the log when I try to do ..... Code: Scanning dcc on local storage ... Using dcc local storage at "modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\dcc\NI00BC00000401022C00.dcc". ConfigName: NI00BC00000401022C00 Version: 003.006 Trying to request configuration file NI00BC00000401022C00,XXXXXX from server ... SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 Camera Configuration file write failed ! Trying to write DCC as PM ... DCC write as PM failed ! thanks for your help ... the thing is I do not speak English and use a translator and there are times when it is difficult to understand hehehehe thanks for the help friends .. that I can do to this phone .... |
10-24-2013, 19:11 | #8 (permalink) | |
Junior Member Join Date: Jul 2013 Location: C:\Program Files\Common Files\
Member: 1985783 Status: Offline Thanks Meter: 10 | Quote:
