Old 02-10-2010, 06:48   #1 (permalink)
Member: 560185
Thanks Meter: 96
Procedure in repairing 6500s sd and SIMLOCK_TEST failed using mx-key..
Phone logs when Scanned in Mx-key:
Phone Type: RM-240 (Nokia 6500s-1)
SW Version: V 10.00 06-03-09 RM-240 (c) Nokia
Imei plain: 35765901674649-9
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
PROCEDURE TO FOLLOW
1.Repair SD
2.SUPER SD Auth
3.PM Write
4.Repair SIMLOCK
Step by Step:
1. Repair SD.
Under IMEI & Security tab click IMEI Rebuild and click "Repair SD". Wait until mx-key finishes it's job..
Sample Log:
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 10.00 06-03-09 RM-240 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 4.906 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
After repairing SUPERDONGLE_KEY, SECURITY_TEST has been damaged.
see status:
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST failed!
proceed to next steps to restore SECURITY_TEST.
2. SUPER SD Auth.
Under PM tab click "SUPER SD Auth". Again wait for mx-key to finish..
Sample Log:
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
After the unit has been authorized, you can now write pm fields 1 and 309.. For my case, i use a complete pm file but chose to skip simlock area.
3. Write good pm file.
Still under PM tab..Locate "Load from file" then click it.. a folder will pop-up asking you to choose the pm file you would like to write.. pick the file then click "Open". Wait for mx-key to finish.
Sample Log:
Completed in 7.828 s
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 40, size 16 bytes written.
- Key: 41, size 182 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 36 bytes written.
- Key: 44, size 182 bytes written.
Section: 2
- Key: 0, size 448 bytes written.
Section: 4
- Key: 1, size 48 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
- Key: 28, size 2 bytes written.
Section: 8
- Key: 1, size 12 bytes written.
- Key: 7, size 8 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 2 bytes written.
- Key: 7, size 1 bytes written.
- Key: 8, size 1 bytes written.
- Key: 9, size 1 bytes written.
- Key: 10, size 1 bytes written.
- Key: 11, size 1 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 2 bytes written.
- Key: 15, size 2 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 2 bytes written.
- Key: 18, size 16 bytes written.
- Key: 19, size 32 bytes written.
- Key: 20, size 32 bytes written.
- Key: 21, size 2 bytes written.
- Key: 22, size 2 bytes written.
- Key: 23, size 2 bytes written.
- Key: 24, size 2 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 29, size 2 bytes written.
- Key: 30, size 2 bytes written.
- Key: 31, size 2 bytes written.
- Key: 32, size 2 bytes written.
- Key: 33, size 2 bytes written.
- Key: 34, size 2 bytes written.
- Key: 35, size 2 bytes written.
- Key: 36, size 2 bytes written.
- Key: 37, size 2 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 2 bytes written.
- Key: 44, size 2 bytes written.
- Key: 45, size 2 bytes written.
- Key: 46, size 2 bytes written.
- Key: 47, size 2 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 2 bytes written.
- Key: 51, size 2 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 2 bytes written.
- Key: 54, size 2 bytes written.
- Key: 55, size 2 bytes written.
- Key: 56, size 2 bytes written.
- Key: 57, size 2 bytes written.
- Key: 58, size 2 bytes written.
- Key: 59, size 2 bytes written.
- Key: 60, size 2 bytes written.
- Key: 61, size 2 bytes written.
- Key: 62, size 2 bytes written.
- Key: 63, size 2 bytes written.
- Key: 64, size 2 bytes written.
- Key: 65, size 4 bytes written.
- Key: 66, size 1 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 4 bytes written.
- Key: 69, size 4 bytes written.
- Key: 70, size 4 bytes written.
- Key: 71, size 16 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 13 bytes written.
Section: 31
- Key: 4, size 16 bytes written.
Section: 42
- Key: 0, size 2 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 40 bytes written.
- Key: 8, size 40 bytes written.
- Key: 9, size 40 bytes written.
- Key: 10, size 40 bytes written.
- Key: 11, size 40 bytes written.
- Key: 12, size 40 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
Section: 50
Section: 54
Section: 66
- Key: 0, size 2050 bytes written.
- Key: 1, size 240 bytes written.
- Key: 2, size 240 bytes written.
- Key: 3, size 1 bytes written.
- Key: 5, size 240 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 4 bytes written.
- Key: 8, size 4 bytes written.
- Key: 9, size 4 bytes written.
- Key: 10, size 240 bytes written.
- Key: 11, size 240 bytes written.
- Key: 16, size 4 bytes written.
- Key: 18, size 4 bytes written.
- Key: 20, size 4 bytes written.
- Key: 22, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 26, size 4 bytes written.
- Key: 28, size 4 bytes written.
- Key: 30, size 4 bytes written.
- Key: 32, size 4 bytes written.
- Key: 34, size 4 bytes written.
- Key: 57, size 8 bytes written.
- Key: 58, size 8 bytes written.
- Key: 59, size 8 bytes written.
- Key: 60, size 8 bytes written.
- Key: 61, size 8 bytes written.
- Key: 75, size 8 bytes written.
- Key: 76, size 8 bytes written.
- Key: 78, size 6144 bytes written.
- Key: 79, size 300 bytes written.
- Key: 80, size 60 bytes written.
- Key: 91, size 3 bytes written.
- Key: 92, size 3 bytes written.
- Key: 93, size 3 bytes written.
- Key: 94, size 3 bytes written.
- Key: 95, size 3 bytes written.
- Key: 96, size 3 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 4 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 4 bytes written.
- Key: 102, size 4 bytes written.
- Key: 103, size 6 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 116, size 120 bytes written.
- Key: 118, size 30 bytes written.
- Key: 119, size 1 bytes written.
- Key: 120, size 8 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 26, size 12 bytes written.
- 120 skipped
Section: 122
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 218
Section: 238
- Key: 1, size 1 bytes written.
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Section: 322
- Key: 0, size 1 bytes written.
Section: 334
Section: 339
- Key: 0, size 511 bytes written.
- Key: 1, size 511 bytes written.
Section: 341
- Key: 4, size 4296 bytes written.
Section: 354
- Key: 0, size 3 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Section: 362
- Key: 1, size 120 bytes written.
Completed in 9.594 s
after pm write, check the status of the unit..
Product Code: 0543754
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST has been restored.. Proceed to next step to repair SIMLOCK.
4.Repair SIMLOCK.
Under "IMEI & SECURITY" click Simlock locate and click "Repair SIMLOCK" in Options menu. Also click "Make SIMLOCK RPL" then then click "Update SpLock". Wait for mx-key to finish.
Sample Log:
Calculating SIMLOCK using security server ...
Completed in 4.672 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 357659016746499
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
After all procedure's are done, scan the unit again to check it's status..
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Unit successfully repaired.. thanks to Mx-key team..
B.R
The Following 7 Users Say Thank You to amats211 For This Useful Post:
Old 02-10-2010, 16:13   #2 (permalink)
wizz25's Avatar
Member: 209093
Thanks Meter: 154
great work mannnnnnnn...
The Following User Says Thank You to wizz25 For This Useful Post:
Old 02-10-2010, 16:58   #3 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
thanks but i got wd enabled just by unlock of 6500s
Fixed after wards
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 02-16-2010, 14:55   #4 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
Language Pack:
- not available.
SIMLOCK invalid!
PROCEDURE TO FOLLOW
1.Repair SD
2.SUPER SD Auth
3.PM Write
4.Repair SIMLOCK
Step by Step:
1. Repair SD.
Sample Log:
see status:
Language Pack:
- not available.
SIMLOCK invalid!
2. SUPER SD Auth.
Sample Log:
Sample Log:
Section: 1
Section: 2
Section: 4
Section: 8
Section: 11
Section: 31
Section: 42
Section: 50
Section: 54
Section: 66
Section: 88
Section: 96
Section: 107
- 120 skipped
Section: 122
Section: 193
Section: 208
Section: 218
Section: 238
Section: 309
Section: 322
Section: 334
Section: 339
Section: 341
Section: 354
Section: 356
Section: 362
Language Pack:
- not available.
SIMLOCK invalid!
4.Repair SIMLOCK.
Sample Log:
Counter: 0/3, 0/10
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
B.R
Can u upload here that nokia 6500s-1 pm please?
Old 02-24-2010, 10:49   #5 (permalink)
Member: 566014
Thanks Meter: 5
Please help after following the above procedure the phone still has contact sevrice Nokia 5310
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 09.42 07-11-08 RM-303 (c) Nokia
Imei plain: 35687002099847-8
Product Code: 0564401
Language Pack:
- not available.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 356870020998478
Counter: 0/3, 0/10
can somebody help and show how to repair SECURITY_TEST failed! ????????????????????????????????????????????????
Old 02-24-2010, 11:32   #6 (permalink)
Registered User
Member: 1026187
Sonork: 1585394
Thanks Meter: 46
@ELIass
Read ALL procedure bro
Old 02-24-2010, 15:21   #7 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 859
Smile Excellent Work
Language Pack:
- not available.
SIMLOCK invalid!
PROCEDURE TO FOLLOW
1.Repair SD
2.SUPER SD Auth
3.PM Write
4.Repair SIMLOCK
Step by Step:
1. Repair SD.
Sample Log:
see status:
Language Pack:
- not available.
SIMLOCK invalid!
2. SUPER SD Auth.
Sample Log:
Sample Log:
Section: 1
Section: 2
Section: 4
Section: 8
Section: 11
Section: 31
Section: 42
Section: 50
Section: 54
Section: 66
Section: 88
Section: 96
Section: 107
- 120 skipped
Section: 122
Section: 193
Section: 208
Section: 218
Section: 238
Section: 309
Section: 322
Section: 334
Section: 339
Section: 341
Section: 354
Section: 356
Section: 362
Language Pack:
- not available.
SIMLOCK invalid!
4.Repair SIMLOCK.
Sample Log:
Counter: 0/3, 0/10
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
B.R
I have Same problem with 6500s
Repaird with Same Method
Excellent Working
Thanks a lot
Br,
Irfan Sheikh
Read ASK and write RPL Using MX-Key mamun_q MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 09-03-2010 14:58
How to use MX Key and JAF Pkey software in same PC? tigran80 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-13-2010 08:17
Blackberry Step by step procedure for unlocking using MX-KEY tims MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 0 02-05-2010 15:16
superdongle key invalid repair using mx key sajidashraf MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 01-25-2010 18:44
@ VDO HOWTO repair contact service ,Start up failed By MX-KEY Tom_ptm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-05-2009 14:26
Page generated in 0.53901 seconds with 8 queries
