Old 02-10-2010, 02:43   #1 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 798
Question E65 sd error
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 4.0615.2 05-06-08 RM-208 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
ERROR: Missing SD BLOCK or PM corrupted !
need to repair sd data
how it could be done
thanks in advance
Old 02-10-2010, 03:29   #2 (permalink)
Member: 145082
Thanks Meter: 798
Phone Type: RM-208 (Nokia E65)
SW Version: V 4.0615.2 05-06-08 RM-208 (c) Nokia.
Imei plain: 35326201113581-0
Product Code: 0515722
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353262011135810
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-10-2010, 03:40   #3 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
you can make all back up section then after that repair SD then repair supper dungle key your problem solve
Old 02-10-2010, 03:42   #4 (permalink)
Member: 145082
Thanks Meter: 798
this is the error with repair sd
Old 02-10-2010, 03:44   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
you need to back all section then restor imei then make repair sd and supper dungle key
Old 02-10-2010, 03:49   #6 (permalink)
Member: 145082
Thanks Meter: 798
done with this single post thanks to all
http://forum.gsmhosting.com/vbb/show...5&postcount=21
Old 02-10-2010, 04:34   #7 (permalink)
Member: 145082
Thanks Meter: 798
no when i repair sd with npc reset the phone goes ok
but when i use restore imei fir imei restore
it again goes to wd 3 min error
Old 02-10-2010, 04:51   #8 (permalink)
Member: 145082
Thanks Meter: 798
the phone is not gettin' network now
what could be done up here....
ApeCoreSw: 4.0633.74.00 04-09-08 RM-208 (c)Nokia
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 44, size 182 bytes written.
Section: 2
- Key: 0, size 440 bytes written.
Section: 4
- Key: 0, size 1 bytes written.
- Key: 1, size 64 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
- Key: 26, size 132 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 16 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 bytes written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 1 bytes written.
- Key: 15, size 1 bytes written.
- Key: 16, size 1 bytes written.
- Key: 17, size 1 bytes written.
- Key: 18, size 1 bytes written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 bytes written.
- Key: 22, size 1 bytes written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 1 bytes written.
- Key: 30, size 1 bytes written.
- Key: 31, size 1 bytes written.
- Key: 32, size 1 bytes written.
- Key: 33, size 1 bytes written.
- Key: 34, size 1 bytes written.
- Key: 35, size 1 bytes written.
- Key: 36, size 1 bytes written.
- Key: 37, size 1 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 bytes written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 bytes written.
- Key: 56, size 1 bytes written.
- Key: 57, size 1 bytes written.
- Key: 58, size 1 bytes written.
- Key: 59, size 1 bytes written.
- Key: 60, size 1 bytes written.
- Key: 61, size 1 bytes written.
- Key: 62, size 1 bytes written.
- Key: 63, size 1 bytes written.
- Key: 64, size 1 bytes written.
- Key: 65, size 1 bytes written.
- Key: 66, size 32 bytes written.
- Key: 67, size 32 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 2 bytes written.
- Key: 110, size 2 bytes written.
- Key: 111, size 2 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 2 bytes written.
- Key: 114, size 4 bytes written.
- Key: 115, size 4 bytes written.
- Key: 116, size 1 bytes written.
- Key: 117, size 4 bytes written.
- Key: 118, size 4 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 4 bytes written.
- Key: 121, size 16 bytes written.
- Key: 122, size 4 bytes written.
- Key: 123, size 2 bytes written.
- Key: 124, size 2 bytes written.
- Key: 125, size 1436 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 17
Section: 26
- Key: 0, size 16 bytes written.
- Key: 1, size 68 bytes written.
Section: 31
- Key: 4, size 12 bytes written.
Section: 44
Section: 50
- Key: 0, size 2 bytes written.
Section: 54
- Key: 2, size 24 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 92
- Key: 0, size 20 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 117
- Key: 5, size 10 bytes written.
- Key: 6, size 8 bytes written.
- Key: 8, size 42 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 217
- Key: 0, size 32 bytes written.
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Section: 313
- Key: 0, size 615 bytes written.
Section: 322
Section: 334
Completed in 5.907 s
Old 02-11-2010, 11:55   #9 (permalink)
Member: 145082
Thanks Meter: 798
Old 02-11-2010, 11:56   #10 (permalink)
Member: 145082
Thanks Meter: 798
now the phone i not gettin' network
3110c showing SD error while sd is ok xim360 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-18-2010 13:29
3110 repair sd error askaralikp MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-15-2010 08:36
5130c after repair sd erRor and sl crrupted ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-03-2010 13:55
6300 after repair sd error ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-03-2010 13:33
n73 calculate sd error 65211355 Universalbox 8 12-12-2009 19:29
Page generated in 0.20332 seconds with 9 queries
