01-15-2010, 11:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | RAP PAPUBKEYS is blank/erased. AND WHEN WHEN THE MOBILE IS NOT SUCCESSFULLY FLASHED THE RESULT IS TWO ISSUES IMEI DAMAGED AS WELL AS PHONE FLASHING FAILED WHAT TO DO IN THIS CASE HERE IN MY SCENARIO NOKIA 5300 HOW TO RESTORE AND PLS STRONGLY ADVICE WHICH PIN TO USE FBUS 7 PIN OR 5 PIN THIS IS THE FIRST ATTEMPT LOG Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 Processing file: rm146__03.50.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.22 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0EA0010888BA7A56626AF411B08721088EA22925 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.078 s CMT NOR area [000006C0-0001FFFF] erased in 0.063 s CMT NOR area [00020000-0007FFFF] erased in 0.125 s CMT NOR area [00080000-000DFFFF] erased in 0.125 s CMT NOR area [00100000-001FFFFF] erased in 0.266 s CMT NOR area [00200000-0031FFFF] erased in 0.297 s CMT NOR area [00320000-0105FFFF] erased in 3.078 s CMT NOR area [01060000-01067FFF] erased in 0.062 s CMT NOR area [01068000-0107FFFF] erased in 0.079 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00020000, Result: 0010 Flashing terminated with error(s) in 32.750 s RX Buffer: C7012D0103CD000010000000F172 SECOND TRIED WITH USB MODE Library version: 1.0.0.11446, Date: 25-11-2009 Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Nokia USB Flashing Generic detached. Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Processing file: rm146__05.00.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.51 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... Connect a CHARGER or Press phone's POWER button and hold for a second please ! [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 0EA0010888BA7A56626AF411B08721088EA22925 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, UPDAPP: 0x38600 bytes Flashing terminated with error(s) in 36.500 s RX Buffer: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 Nokia USB Flashing Generic detached. NOW I DONT KNOW WHERE THE RPL HOW CAN I RESTORE ????? PLS ADVICE NOW I DONT KNOW WHAT IS THE STATUS OF IMEI |
01-15-2010, 12:05 | #4 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Valencia, Spain
Member: 867007 Status: Offline Thanks Meter: 42 | first uncheck rx2 in mobileex and restart program, and after each file is flashed and the box restarts try to press shortly power button on the phone and see if rx led on the box is on. or you can try to flas firmware files one by one, i mean load all files in soft, and afer mcu is flashed and gives errors, uncheck mcu and flash again and so on... |
01-15-2010, 12:15 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
MXKEY need 7PIN for RX2 line this tool have auto set that,event disable in options. phone have Code: RAP PAPUBKEYS is blank/erased. your log say. Code: Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00020000, Result: 0010 Flashing terminated with error(s) in 32.750 s RX Buffer: C7012D0103CD000010000000F172 if RAP PAPUBKEYS writeln . then buscheck log must be Code: ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 Code: ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF backup CMT RPL can use this way. but only CMT,no need local mode. br, | |
03-17-2010, 00:10 | #10 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: esmeraldas-ecuador
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | Quote:
RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 178000129AB35850ABF9A7214F51604B22F9E0CF ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Reading RAP NPC (0x0 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Flash Imei: 00000000000000 NPC_DATA is empty. RPL saved to "C:\mobileEx\3.3\data\backup\BB5_00000000000000_BA CK.rpl" now what do i have to do helpme tanks | |
03-31-2010, 01:57 | #15 (permalink) |
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | i was traite to make the erase but i make a mistake when you traite to disable the eprom in mxkey there is a rap file to i erase the rap only no the eprom thats what happend them rpl went 000000000000 now you understand |
RAP PAPUBKEYS is blank/erased | peace_bird_fr | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-15-2010 18:22 |
6500s Cmt keys are blank/erased | shak360 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-06-2010 21:20 |
6500s RAP PAPUBKEYS is blank | mordant | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-11-2010 17:54 |
3pcs N70..RAP PAPUBKEYS is blank/erased. | APOLLO MOBILE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-11-2010 13:34 |
APE PAPUBKEYS is blank/erased | gprsman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 11-01-2009 12:17 |
