Old 06-26-2010, 14:16   #1 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
repair sd working or not??
hi
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1C7002135E0F7E56A3844215D6CEFDA42F088FFF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 351xxxxxxxxxxxx
Original Product code: 0550573
Bluetooth ID: 00240488FB4D
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35xxxxxxxxxxxxxxx
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
TimeStamp: 2008-11-12T09:10:26Z
SW Version: 07.21
Variant Version: 013
ProductProfile: RM237_0514950_07.21_013.spr
Simlock: 0514950_simlock.bin
Imei net: 351xxxxxxxxxxxx
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
3110c contact service..after repair sd and super sd auth write pm problem is same security fail??? server work properly?
thanks..
Old 06-26-2010, 14:20   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
Hi, I see your phone log so thats problem is not of repair sd.
In this problem you need to write 1 or 309 pm area by pm auth.
Its Simple.
Let me know you want any more info.
Br.
Shashank
Old 06-26-2010, 14:40   #3 (permalink)
Member: 20038
Thanks Meter: 19
use the magic button recover sertificat or klick load rf bb from server and than write..
Old 06-26-2010, 15:20   #4 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
yes i write pm manually also load rf bb 1 309 but same problem i already repair lots of 3110 be for. i also check hardware it is ok...
Old 06-26-2010, 15:28   #5 (permalink)
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@**RAJESH**
If u have done this all, then i am sure its 100% hardware fault or may be water damage case.
Reason :- Security test failed problem, 4% cases solved by hardware , if your hands are big in hardware so you can do it.
Sorry for hardware tips, i dont know about it.
If anything else regarding this issue, you can contact me @ yahoo messenger any time.
Br.
Shashank
Old 06-28-2010, 08:43   #6 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
When i rcv phone from customer only restart problem ............
Old 06-28-2010, 10:14   #7 (permalink)
div_raj's Avatar
Member: 59732
Thanks Meter: 47
WRITE RPL_collection_V1__without_NPC_DATA__made_by_MxKey YOUR PROBLEM CAN BE SOLVED
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 14:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 22:31
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Page generated in 0.34668 seconds with 8 queries
