05-03-2010, 20:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | ---=={ Report Here The Bugs in 3.4 Rev1.0 }==--- I have just flashed DCT4 phone with new version and kool man..... No errors, Thats great.... Please post your problems here. Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm74__5.400 as MCU [DCT4,DCT4 ALGORITHM] size: 6.77 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 2031 ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00020D42:9C6BDA60 Area [01000000-0101FFFF] erased in 1.047 s Area [01020000-017BFFFF] erased in 51.016 s Area [01F20000-01FDFFFF] erased in 5.235 s Flash programming ... Programming completed in 1 min 42.875 s File Processed in 2 min 53.359 s Processing file: rm74__5.40.image_ora_uk as CNT [DCT4,DCT4 ALGORITHM] page size: 64 K size: 896.76 KB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 2031 ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00020D42:0BDFDA6A Area [01C00000-01F1FFFF] erased in 20.453 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 12.234 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.141 s File Processed in 54.703 s Processing file: rm74__5.40o as PPM [DCT4,DCT4 ALGORITHM] size: 1.20 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 2031 ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00020D42:2984DA60 Area [017C0000-01BFFFFF] erased in 27.922 s Flash programming ... Programming completed in 19.016 s File Processed in 58.344 s Flashing completed in 4 min 46.532 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-74 (Nokia 6030) SW Version: V 5.40 15-05-07 RM-74 (c) Nokia. Imei plain: 35837****** Imei OTP: 3583780****** Product Code: 0524937 Cellular System: GSM ASIC ID: 0x2031, type: 2 Ppm Id: O Language Pack: English,French,German,Italian,Spanish,Turkish Imei net: 358378******** Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 4 min 58.468 s |
The Following 4 Users Say Thank You to adnann5 For This Useful Post: |
05-03-2010, 20:37 | #2 (permalink) |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Dct rpl??? What happened to DCT4 RPL Service??? Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone Type: RM-74 (Nokia 6030) SW Version: V 5.40 15-05-07 RM-74 (c) Nokia. Imei plain: 35837800****** Imei OTP: 3583780******* Product Code: 0524937 Cellular System: GSM ASIC ID: 0x2031, type: 2 Ppm Id: O Language Pack: English,French,German,Italian,Spanish,Turkish Failed to read SP data |
The Following User Says Thank You to adnann5 For This Useful Post: |
05-03-2010, 21:56 | #3 (permalink) | |
Insane Poster Join Date: Mar 2008 Location: jakarta
Member: 731821 Status: Offline Thanks Meter: 4 | Programming UEM Imei (OTP) ...failed -> because UEM have OTP ( One Time Programming ) after write rpl have Quote:
no bug yet. | |
05-04-2010, 08:56 | #4 (permalink) |
Registered User Join Date: Sep 2005 Location: (earth°) Age: 46
Member: 181110 Status: Offline Sonork: 1001648353 Thanks Meter: 180 | imie 1208 write failed with method2 this is the log what is the problem please . Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.4 ERROR: could not calculate data, server return false ! |
05-04-2010, 09:03 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | http://forum.gsmhosting.com/vbb/f605...-3-4-a-991397/ a new bug in bb tool |
05-04-2010, 13:19 | #6 (permalink) |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | BlackBerry Blackberry code calculation is not working???? Shows only this.. BB module version: 1.02 Initial Alpha Release BB Module Ready. IMEI: 3584730****** MEP: MEP-07723-005 SERVER->Served by MXKEY - BLADE X at host3, agent version 1.0 revision 1.4 IMEI: 3584730***** MEP: MEP-07723-005 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.0 revision 1.4 Please solve it MX-Team TIA |
07-23-2010, 17:00 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Using online logger(After this mobile is still at sim registartion failed)What should i do? ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0018D435A3BDA66 ASIC type: 11 UEM Imei: 35829503123499 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35829503123499.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0018D435A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 35829503123499-4 Product Code: 0550579 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: - not available. Imei net: 35829503123499 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
