Old 01-18-2011, 17:40   #1 (permalink)
DANY77's Avatar
Member: 138995
Thanks Meter: 11
Reset User security code in X2 with usb cable
Hi i try to flash the phone for reset security code but not work.What can i do for reset the phone??
Thanks a lot.
Old 01-18-2011, 17:49   #2 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 554
Thanks a lot.
this proses via usb
1 . select correct mcu file in correct tab
2 . pres bus check
3 . now power the phone and wait for scanning the phone
4 . after scanning the phone you see new service tab near flashing tab
5 . in service tab you easily reset your phone
don't forget to press thanx
Br,
Master Mobiles
The Following 9 Users Say Thank You to master mobiles For This Useful Post:
Old 01-18-2011, 22:31   #3 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
I did the same with Nokia C3 and many other BB5 fones via USB but always failed. Each time after Mxkey found fone on USB software hanged at "Pooling ADL Device". I left the Mxkey main Window untoched for about 15 mins but fone not found.
The only way is to Flash the fone and if by luck Service tab is enabled after flashing then we can do UI Settings otherwise just NO WAY.
I failed to get the Service tab enabled by MCU file selected and clicking the BUS CHECK and also after flashing.
What is the correct way to work around? Or Am I Doing some mistake? Because many times this Service tab becomes bottle neck for me.
Waiting for some working tip.
Best Regards!
yawarniazi
Old 01-19-2011, 15:09   #4 (permalink)
DANY77's Avatar
Member: 138995
Thanks Meter: 11
Originally Posted by master mobiles View Post
this proses via usb
2 . pres bus check
Br,
Master Mobiles
Not work for me...can you help me??
Old 01-19-2011, 15:26   #5 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
bro use fbus cable with new hashes support box like atf or any other because on usb its ask for driver and driver will not detect till security code locked.
Old 01-19-2011, 15:33   #6 (permalink)
DANY77's Avatar
Member: 138995
Thanks Meter: 11
Now working...thanks a lot for info
Old 01-19-2011, 15:45   #7 (permalink)
sharlen's Avatar
Member: 616567
Thanks Meter: 187
use BEST dongle bro....tested via USB.
Old 01-19-2011, 18:14   #8 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 554
Thanks a lot.
contact me on my yahoo id ([email protected] )
may be i will help u........
The Following 2 Users Say Thank You to master mobiles For This Useful Post:
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.18492 seconds with 9 queries
