Old 01-12-2010, 20:46   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
resolve Security Test on 5800
hello all,
I'am a new user in this small and in the same time bix box ,
I have one 5800 security test failed, usualy with other box I get SX4 and after write field 1 and 309, but this not resolve my probleme,
anny help or information pls ?, I use search boutton like all the time but don't find anny think,
Best Regards,
JAVA Good.
Old 01-13-2010, 02:37   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
sound like after repair SIMLOCK / SUPERDONGLE with UB / MT
can u do PMM Auth / SX-4 with MXkey service ?
security test failed : can be CCC or HWC not sync or empty ( ussualy after erase / modify )
but in this case phone have protected frimware,that make not easly to repair.
try with cross frimware flashing, and repair that.
better put info log here
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 01-13-2010, 11:12   #3 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
hoooo, tks for your reply,
I can get SX4 with Mx-Key with out probleme, and write field 1 and 309 like many time with other box, but can't repaire security test,
about write CCC and HWC, normaly I can write it with out probleme why I need cross flash the phone, this is only for write back the field 308, and my field 308 is good,
I have a charging probleme, and after many search I see some peopel can repair this only with flasing, if don't work, I go to hardware probleme,
Best Regards,
JAVA Good.
Old 01-13-2010, 11:13   #4 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
and sorry I forget, can share CERT file CCC and HWC pls if you have a good one ?
Best Regards,
JAVA Good.
Old 01-13-2010, 21:57   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
try with this one
download
br,
Old 01-13-2010, 22:03   #6 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
big tks but link don't work for me, maybe an other link pls,*
Best Regards,
JAVA Good.
Old 01-13-2010, 22:05   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
link working good here.
i can't upload other,cos limited internet connection
BR,
Old 01-13-2010, 22:31   #8 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
work only now, tks for your help, I post the result tomorow,
Best Regards,
JAVA Good.
Old 01-14-2010, 17:56   #9 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
hi,
I write your file and get the SX4 and after this write the field 1 and 309, but security test failed again ?
realy strange, if I erase all and restore my field 308 with cross flash and restole all, this can correct the probleme ?
Best Regards,
JAVA Godd.
Old 01-14-2010, 18:13   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u read back . FULL RPL backup and send here
maybe with LOG .
br,
Old 01-15-2010, 12:33   #11 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
maybe my customer get it back for me, I share the back up of RPL I have with cyclone,
and why you speack about credit, Mxkey have some option with credit ? (sorry for this question because I'am new in Mxkey )
Best Regards,
JAVA Good.
Old 01-15-2010, 12:51   #12 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
wich one ?
never spoke about credit . but i need RPL backup and log info in mxkey soft.
that i mean .
br,
Old 01-15-2010, 17:52   #13 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
I'am verry tired, I don't share my RPL file, forget sorry, I resole my probleme, just bad field 1 and 309, I test an other one and all is good,
tks for you MobileEx-Team, and have a stupid question, where is unlock boutton on Mxkey ?
Best Regards,
JAVA Good.
Old 01-15-2010, 23:56   #14 (permalink)
mrnazam's Avatar
Member: 1001269
Thanks Meter: 226
Originally Posted by MobileEx-Team View Post
try with this one
download
br,
sir please chack this link or give this link i have same problem
Old 01-16-2010, 07:43   #15 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
Best Regards,
JAVA Good.
HI
Goto Service TAB > IMEI and Security their u see Simlock Option
Click on it now click SPLock Info to see if all is ok with your SIMLOCk
then Press update Splock ..(make sure init simlock is ticked)
Hope u get it
Cant Repair Security Test Failed on N96 and 5800 powerplay83 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 23 02-09-2010 17:51
HELP MX TEAM NOKIA 5800 RM 428 security test failed!!!! michael garcia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-08-2010 02:22
5800 security test failed contact service,done shahinahmed007 Nokia Base Band 5 ( BB-5 ) 4 02-06-2010 21:08
5800 contact retailer security test failed sx4 not sucess. why?????? shahinahmed007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 22 02-02-2010 14:33
security test Fail nokia 5800 [SOLVED] langin Cyclonebox 10 01-10-2010 22:34
Page generated in 0.24288 seconds with 9 queries
