08-21-2009, 05:20 | #1 (permalink) | ||
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Rh-105 1208 not flash by mx-key Quote:
09-05-2009, 16:40 | #6 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | Quote:
r u see this extbusc: Ffff ffff ffff ffff ffff ffff ffff ffff (u have this error) and this ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 (if u not have problem) 1.cable 2.fia 3.interface wbr | |
The Following 2 Users Say Thank You to mohA™ For This Useful Post: |
09-06-2009, 01:00 | #10 (permalink) |
Freak Poster Join Date: Apr 2007 Location: malaysia
Member: 483720 Status: Offline Thanks Meter: 117 | try upgrade latest V. it's ok.......... Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00152A20A3BDA66 ASIC type: 11 UEM Imei: 359316027xxxxx Processing file: rh105_05.910 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00152A20:2984DA60 Programming MCU ... FlashImage: rh105_05.910 [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 1.296 s Area [01010000-013AFFFF] erased in 1 min 13.407 s Area [013B0000-013EFFFF] erased in 5.046 s Area [017C0000-017EFFFF] erased in 0.093 s Area [01FC0000-01FEFFFF] erased in 0.093 s Flash programming ... Programming completed in 13.657 s File Processed in 1 min 42.688 s Processing file: rh1050_nai5.91md ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00152A20:2984DA60 Programming Content Pack ... FlashImage: rh1050_nai5.91md [DCT4,DCT4 ALGORITHM] size: 147.47 KB Supported Ids: 2292 Area [01380000-013AFFFF] erased in 3.797 s Flash programming ... Programming completed in 0.937 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.032 s File Processed in 16.187 s Processing file: rh105_05.91md ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00152A20:2984DA60 Programming PPM ... FlashImage: rh105_05.91md [DCT4,DCT4 ALGORITHM] size: 1.25 MB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 1.265 s Area [01250000-0137FFFF] erased in 24.000 s Flash programming ... Programming completed in 8.125 s File Processed in 39.032 s Flashing completed in 2 min 59.406 s After Flash Processing ... Updating Product Code OK. Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Uploading Product Profile Decompressing RH105_0549915_3.72_001.spr to C:\PROGRA1\Nokia\Phoenix\Products\RH-105\ OK Failed! PhoneType:RH-105 SwVersion: V 5.91 27-03-09 RH-105 (c) NMP MCU file: rh105_05.910 Trying to find patch position ...OK, case id: 3 Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00152A20:2984DA60 Area [01000000-0101FFFF] erased in 2.562 s Area [01160000-0117FFFF] erased in 2.547 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 23.015 s Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 359316027xxxxx-9 Product Code: 0549915 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MD Language Pack: - not available. Imei net: 359316027xxxxx Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 4 min 0.921 s |
The Following 3 Users Say Thank You to ptnetwork For This Useful Post: |
2610b rh87 not supported by mx-key??? | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-21-2010 08:22 |
nokia 2610b usa imei not writen by MX KEY | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-13-2010 13:18 |
3120c SECURITY_TEST failed! NOT solved by MX KEY[SOLVED] | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-11-2010 07:33 |
Sx4 not done by mx key | sumon.bd | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 07-01-2009 19:37 |
RH-105 1208 Successful Flashing Log By jafsupport.com | SmartFlasher™ | J.A.F. By Jafsupport.com | 7 | 02-06-2009 06:49 |
