10-09-2010, 10:59 | #1 (permalink) |
Registered User Join Date: Jul 2007 Location: adana Age: 44
Member: 557525 Status: Offline Thanks Meter: 67 | rh-93 1110i unlock solve Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008D1D5A:2984DA60 ASIC type: 2 UEM Imei: 35364401476854 Flash Imei: 35364401476854 MasterCode: 4163544011 RPL saved to "C:\mobileEx\3.4\data\backup\35364401476854_BACK.r pl" Phone Type: RH-93 SW Version: V 5.53 20-07-06 RH-93 (c) NMP Imei plain: 35795700384303-4 Product Code: 0532991 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AD Language Pack: English,French,German,Turkish Imei net: 35795700384303 Version: Counter: 0/3, 0/10 CONFIG_DATA: D43D4E221930AB88 PROFILE_BITS: 59D2F5B3450117B9 SIMLOCK_DATA corrupted! problem solve pls? |
10-09-2010, 11:18 | #2 (permalink) |
Member: 557525 Status: Offline Thanks Meter: 67 | Imei net: 353644014-------- Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-93_35364401476854_SIM.RPL" Updating SIMLOCK ...ERROR: 01 Reading Simlock info ... Imei net: 3536440147--------- Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF thıs solve ????????????????? PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED |
10-09-2010, 12:49 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | erase eeprom: - get addr, untick safe erase, select eeprom. - repair sl, direct (rsa method) - write pm, skip simlock part. - full factory BR |
The Following User Says Thank You to gbluez For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
