07-05-2009, 12:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | rh99 flashing problem .? Code: Processing file: rh99_05.230 ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001DDA04:2984DA60 Programming MCU ... rh99_05.230: [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 1.047 s Area [01010000-013AFFFF] erased in 58.219 s Area [013B0000-013EFFFF] erased in 4.000 s Area [017C0000-017EFFFF] erased in 0.047 s Area [01FC0000-01FEFFFF] erased in 0.078 s Flash programming ... Programming completed in 14.625 s File Processed in 1 min 23.688 s Processing file: rh990_nai5.23mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001DDA04:2984DA60 Programming Content Pack ... rh990_nai5.23mg: [DCT4,DCT4 ALGORITHM] size: 151.83 KB Supported Ids: 2292 Area [01380000-013AFFFF] erased in 2.953 s Flash programming ... Programming completed in 0.937 s Content extract fail, continue anyway ... File Processed in 41.656 s Processing file: rh99_05.23mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001DDA04:2984DA60 Programming PPM ... rh99_05.23mg: [DCT4,DCT4 ALGORITHM] size: 996.36 KB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 0.985 s Area [01250000-0137FFFF] erased in 18.890 s Flash programming ... Programming completed in 6.078 s File Processed in 33.766 s Flashing completed in 2 min 42.188 s Phone not responding ! Total time to process is 3 min 2.250 s |
07-05-2009, 13:43 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
PLS CHECK IN THE FLASHING LOGS THAT URE SET DIDN'T REPLY ON CNT FLASHING AND IT FAILED Content extract fail, continue anyway ... SO PLS CHECK IN THE HARDWARE AND FLASH THE SET WITH THE LATEST 5.91 MCU FILE HOPE IT WILL BE ALIVE AGAIN WBR sahil2000ind | |
07-07-2009, 06:11 | #5 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Worldwide Best Server
Member: 639209 Status: Offline Sonork: 100.1627284 Thanks Meter: 69 | @THE ANT, JUST follow the pic.. 10000% tested your problem will be solved... cover one interface then flash again Quote:
The Following User Says Thank You to Macwin™ For This Useful Post: |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
Flashing Problem UniversalBox 6110 Nokia Flashing Problem No available Boot Loader | Ravi Potdar | Universalbox | 1 | 05-29-2009 15:00 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
need 1200 Rh99 flash fill | rana4star | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 09-28-2007 13:46 |
N3210 flash problem. flash id:FFFFFFF | pali | Nokia Hardware & Hardware Repair | 7 | 05-26-2002 22:48 |
